Failure Prevention Thread
Old Mar 1, 2015 | 06:29 PM
  #91
SpringerPop's Avatar
SpringerPop
What passenger-side power steering line do you have? Mine are all on the driver's side.
Of course, as always, YMMV.
Pop
Old Mar 1, 2015 | 09:09 PM
  #92
exbxtoy's Avatar
exbxtoy
Pop
I should have been more specific. Mine are on the drivers side as well. Out of the two lines at the top near the firewall, the one that is to the passenger side is loose on mine, and leaking oil.
Old Mar 15, 2015 | 07:09 PM
  #93
tjmike's Avatar
tjmike
Is replacing the fuel filter bowl o-rings a common enough issue to warrant being on this list?
Old Mar 16, 2015 | 06:19 AM
  #94
JayTheCPA's Avatar
JayTheCPA
My vote is 'Yes' especially if somebody buys the truck without a known repair history.
Old Mar 16, 2015 | 08:55 AM
  #95
SDElwood's Avatar
SDElwood
Beer Fridge Finder
Wow! This is an awesome thread! Tuning in!
Old Nov 17, 2015 | 04:16 PM
  #96
bearman113's Avatar
bearman113
Alaska Chapter ******
Changed out my gp's over the summer, not my idea of fun (my first time changing them), thermostat and housing, and gp relay for the 2nd time. Printed out the thread and will work on the other things listed here as I can. Thanks for all the great information.
Old Nov 17, 2015 | 09:38 PM
  #97
SpringerPop
Yup. Where you live, glow plugs are a MUST!
However, given the number of these truck used on the North Slope, they must be OK for severe cold.
I'll never know.....
Pop
Old Jan 16, 2016 | 12:15 AM
  #98
CEPNewbie's Avatar
CEPNewbie
Thanks to all for contributing to this thread, just bookmarked it, my punch list just grew to 2/3 pages.
Old Jan 18, 2016 | 01:52 PM
  #99
SDElwood's Avatar
SDElwood
Beer Fridge Finder
My truck had decided that it doesn't like cold. I did all eight glow plugs about a year ago, and it started and was happy all the time. I did the LED thing off the plug side of the relay, and sometimes it comes on, and sometimes it doesn't. If I pop the hood and use pliers to jump the relay, energizing the glow plugs, it's happy as heck. What is not telling the GPR to fire?
Old Jan 18, 2016 | 01:54 PM
  #100
F250_'s Avatar
F250_
Could be your Glow Plug Relay??
Old Jan 18, 2016 | 01:58 PM
  #101
Brother Les's Avatar
Brother Les
Will this help you?
Welcome to guzzle's White-Rodgers (Stancor) GPR replacement Mod Web Page
I use this. It will test your batteries/GPR and Alt at the same time.
Amazon.com: INNOVA 3721 Battery and Charging System Monitor: Automotive Amazon.com: INNOVA 3721 Battery and Charging System Monitor: Automotive
Old Jan 18, 2016 | 02:08 PM
  #102
F250_'s Avatar
F250_
Good thought, Les, on the volt meter. If the GPR is kicking in, you will see about a 2 volt drop (give or take) after turning on the ignition key and then a corresponding increase in voltage once the timer circuit turns the GPR off again.
Old Jan 18, 2016 | 03:41 PM
  #103
SDElwood's Avatar
SDElwood
Beer Fridge Finder
The GPR will only kick in once in a while. Not every time.
Old Jan 18, 2016 | 04:02 PM
  #104
F250_'s Avatar
F250_
First startup in the morning, though, is a guaranteed opportunity.
Old Jan 18, 2016 | 04:29 PM
  #105
SpringerPop
Whenever I'm not towing, I use my Prodigy 3 brake controller in "troubleshooting" mode, which gives me the battery voltage reading.
It's obvious when the GPR shuts off.
Pop
