vacum pump?
Old Mar 5, 2011 | 11:35 PM
johnboggs21's Avatar
johnboggs21
Originally Posted by wreckinball
needs some suck, now thats a quote! hahaha.
I get a feeling thats gonna end up in someones sig lol
Old Mar 5, 2011 | 11:38 PM
wreckinball's Avatar
wreckinball
yeah like mine in a few haha
Old Mar 6, 2011 | 12:11 AM
84-6.9L's Avatar
84-6.9L
Its free for the taking. Dont be shy
Old Mar 6, 2011 | 10:14 AM
gumper 123's Avatar
gumper 123
just put a gauge on vacum hose i pulled off going to booster jumped right up to 18 and droped to 5 and stayed should i replace pump?
Old Mar 6, 2011 | 10:47 AM
84-6.9L's Avatar
84-6.9L
Did you plug the line to the booster? When my booster went bad i would be sitting at a stop light and the pedal would creep back at me. But with the system having vaccum the check valve on the booster should keep vac in it. Charge the system shut the truck off drain the sysetm by pulling a vac line besides the one for the booster. Then pull the bootser line is there a woosh of air?
Old Mar 6, 2011 | 11:02 AM
gumper 123's Avatar
gumper 123
I pulled line going to booster have about 5inch just did the same to my 94 i have 24 inch of vacum.
Old Mar 6, 2011 | 11:10 AM
84-6.9L's Avatar
84-6.9L
switch check valves and see if it changes. Is the pedal always hard or does it work once and then not twice? So the pump on the 92 is at 18 right off the pump and the 94 is at 24?
Old Mar 6, 2011 | 11:34 AM
84-6.9L's Avatar
84-6.9L
The way its sounds its the pump. When you cahange pullys use a power steering pump puller dont use a regular jaw puller and install it on the newpump by oiling the shaft and useing the bolt and bearing to press it on. Most auto parts stores let you rent them for free. heck even bring the pump in and they might even do it for you. but dont be suprised at the cost of that little pump. mine was around 123 bucks and i didnt have a good core either.
southwest395
Dec 20, 2020 11:05 AM
timmosazz
Jul 24, 2006 11:26 AM
Johnthemusher
20
Apr 13, 2006 03:31 PM
otter2208
Apr 29, 2003 04:15 PM
