repairing volare hack install!
Old Aug 22, 2011 | 05:31 PM
  #121
sdetweil's Avatar
sdetweil
Originally Posted by BACAGrizz
Dang Sam,
Looks like the Volare isn't the only thing they hacked up. I see lots of welding and grinding in your future.
yeh.. did I post a pic of the floor? will do
Sam
Old Aug 22, 2011 | 08:38 PM
  #122
rtcalabrojr's Avatar
rtcalabrojr
Darksider
Sam, its been awhile since i have checked your progress. WOW i see you have been busy and from what others have said plenty more ahead! LOL Well keep up the Great work!!
Old Aug 22, 2011 | 10:59 PM
  #123
sdetweil's Avatar
sdetweil
Sam
here is the floor hack to fix
Old Aug 23, 2011 | 04:56 AM
  #124
Drewski 2's Avatar
Drewski 2
Well now.........I don't think I've ever seen a column drop mounted that way. It appears the PO really thought waaaaay outside the box.
Great photos and documentation in this thread.
Old Aug 23, 2011 | 07:31 AM
  #125
jniolon's Avatar
jniolon
old and in the way
Hey Sam,
this morning was the first time I've read through the whole thread... You've really done a fantastic job... all you fab/install work looks professional. When you get in business... you can do my work !!!
I'm jealous of that sway bar... what did it come from ??
your conversation with Grizz about the copper backer plate was a big help... I had a piece of 2" x 1/4" buss bar I used and it's disappeared... Headed to the scrap pile to find a piece of pipe to 'hammer down' thanks for the tip...
later
John
Old Aug 23, 2011 | 08:28 AM
  #126
sdetweil's Avatar
sdetweil
Originally Posted by jniolon
Hey Sam,
later
John
sway bar was part of the MII kit I bought. they sell it separately
here is a link to the the bushing kit, that will get you their phone number.
mustang II sway | eBay
Sam
Old Aug 23, 2011 | 04:59 PM
  #127
sdetweil's Avatar
sdetweil
I also didn't mention that when I put the front spindles/brakes together on Sunday, I discovered that the bracket that holds the caliper to the spindle on the drivers side wasn't even threaded, so the slider bolts the caliper sits on couldn't be retained.. fun..
took a while to find the receipt with the order number..
they are sending a set of brackets.. so, never a dull moment.
(purchased 3/8)..
Sam
Old Aug 24, 2011 | 02:43 AM
  #128
Ravenheart's Avatar
Ravenheart
Hi Sam,
Just went over the whole thread and wanted to drop a line to repeat what the others have said, great work and documentation on the process. Realy gets me hoping to make some progress soon.
Thanks for being and inspiration to those of us behind.
Ed.
Old Aug 24, 2011 | 08:31 AM
  #129
BACAGrizz's Avatar
BACAGrizz
Man, now that you repost the floor pic you do have a lot of welding and grinding to do. I just looked at Dennis Carpenter and they have the left and right floor pans for the 53-55 and the right side for 56 with battery cutout. Have you checked them out yet?
Old Aug 24, 2011 | 12:28 PM
  #130
Björn's Avatar
Björn
That is a lot of work there Sam
But it's good hands
Old Aug 24, 2011 | 12:59 PM
  #131
sdetweil's Avatar
sdetweil
its right down the middle of the floor, and I would need all 4 patch panels to use something new. One of our members had a cab with a toasted ceiling and corners, and cut out the center section for me.
now that the front end is done, I can move on to that repair.
I think I am going to use panel adhesive instead of welding, I have enough for a good overlap, and have clecos to clamp with
Sam
Old Aug 24, 2011 | 01:07 PM
  #132
BACAGrizz's Avatar
BACAGrizz
Excellent. Let us know how it works.
Old Aug 24, 2011 | 02:25 PM
  #133
sdetweil's Avatar
sdetweil
will do, but I'm going to do that in the other topic, cause this one is about the volare, and its done except hooking up the steering again, which is now stuck behind the floor and dash projects..
the floor topic is here
https://www.ford-trucks.com/forums/1...l#post10316446
the dash topic is here
https://www.ford-trucks.com/forums/1...l#post10728875
Sam
Old Dec 31, 2011 | 05:54 PM
  #134
sdetweil's Avatar
sdetweil
here is a link to the cab floor repair topic..
https://www.ford-trucks.com/forums/1...l#post10770118
Sam
Old Dec 31, 2011 | 06:04 PM
  #135
sdetweil's Avatar
sdetweil
I finally made enough progress that we could put the front clip back on today. the engine wiring is almost done, o2 sensors, and the standard: alternator, starter, battery hookups to go.. before rewiring the truck itself.
we found covers for the truck engine intake, so we don't have to convert to the car intake to make it look nice..
lots of room up front for the radiator and electric fan..
Sam
