repairing volare hack install!
Old May 1, 2011 | 03:53 PM
  #106
sdetweil's Avatar
sdetweil
engine mounts built, welded in and next section of chassis painted
Sam
Old May 1, 2011 | 04:34 PM
  #107
BACAGrizz's Avatar
BACAGrizz
Looks good. Where did you find the tube?
Old May 1, 2011 | 04:35 PM
  #108
sdetweil's Avatar
sdetweil
I cut em off the old volare clip!..
Sam
Old May 1, 2011 | 06:50 PM
  #109
mnicosia23's Avatar
mnicosia23
Turning out really good!
Old May 1, 2011 | 07:11 PM
  #110
sdetweil's Avatar
sdetweil
thx.. replaced the second pic, from camera instead of cell phone
Sam
Old May 1, 2011 | 08:36 PM
  #111
Layed Out 100's Avatar
Layed Out 100
looks good, very clean looking.
Old May 14, 2011 | 04:29 AM
  #112
SVT-F100's Avatar
SVT-F100
Sam,
This is the first time I am seeing your thread build. Looks AMAZING!!! The x-member is impeccable and those motor mount supports you fabbed up look stout. Most of all I have to give you credit. I went from a straight frame to an IFS, you Cut out a Volare prepped your frame and then went MII. Mad skills congrats.
Will you be doing the same Column set up as in your other truck? (Ididtit column AOD and Lokar cable kit)
Great job again. And please keep them pictures coming...
Old May 14, 2011 | 06:46 AM
  #113
sdetweil's Avatar
sdetweil
Originally Posted by SVT-F100
Sam,
thanks. on the Column, yes, I found CPP is selling a generic column, 3 or 4 speed.. for 1/2 the Ididit price.. Universal Chrome Tilt Steering Column With Shifter 30" | eBay
the truck had floor shift, but I'm not sure I need that with the center console we'll put in. Now just have to repair the floor. Link to topic
the drivetrain will be a 383 stroker, 450hp with fuel injection and all pretty front parts, with a built up 700r4 OD tranny in front of the 9in thats already there.
| edit.. we decided to do a late model 5.3 EFI GM engine, still keeping the 700-r4 and 9in. later pics show it installed.
and I'm not near the master on volare repair as our friend John Niolon.
Mine were just rectangular pieces for repair, cause of the poor install, John's was the real deal,Removing A Volare Clip and Installing a Mustang II IFS Unit, by John Niolon.
But he gave me confidence that I could do it!.
column info pic below, has both step and straight shift arms, 3 & 4 speed glass (shown below) lighted I think.
tilt, shift, emergency, turn. GM harness connector, late model splines for typical wheel adapters.
my ididit shift column does not have the gear window.
Sam
Old May 14, 2011 | 01:18 PM
  #114
low54's Avatar
low54
great thread Sam, always nice to see complete pics with explanations...Rake looks good as well, also, I swapped my tie plates for my new 9inch cause the old dana44 plates didn't work...I had to re-work the rear shock placement. what I'm getting at is I found inexpensive plates at the local trailer world...They worked good however, I had to grind them down a bit due to being a bit wide for my u bolts to line up and not angel into the perch...another thing, i won't rip on the SBC placement, you earned bragging rights with the 55...lol
Old Jul 9, 2011 | 11:51 AM
  #115
Björn's Avatar
Björn
this is a good topic to read
Nice work there Sam and looking good
Old Aug 22, 2011 | 01:59 PM
  #116
HEAVY100's Avatar
HEAVY100
good thread , any updates ?
Old Aug 22, 2011 | 02:06 PM
  #117
sdetweil's Avatar
sdetweil
the front suspension was finished yesterday..
danged hot here.. 67 days over 100.. and counting.. new all time record on wed probably.. forecast is same thru next friday (12 days from now) at least..
will start to work on the cab floor next..
anybody done a dash repair on a 56? the PO really hacked away at this one..
full panel vs patches?
Sam
Old Aug 22, 2011 | 02:15 PM
  #118
Björn's Avatar
Björn
Sam got any pictures of it ?
Old Aug 22, 2011 | 04:09 PM
  #119
sdetweil's Avatar
sdetweil
heres one
Sam
Old Aug 22, 2011 | 04:38 PM
  #120
BACAGrizz's Avatar
BACAGrizz
Dang Sam,
Looks like the Volare isn't the only thing they hacked up. I see lots of welding and grinding in your future.
