Electrical Issues after brake switch replacement
Old Mar 5, 2011 | 08:42 AM
shelton3's Avatar
shelton3
Replacd the brake switch yesterday for a abs light on dash issue. Now I have no power windows,interior dome lights,or windshield wipers,all fuses checked good.Anyone had anything like this 2000 excursion deisel
Old Mar 5, 2011 | 09:24 AM
jh818's Avatar
jh818
Did it at least fix your ABS light problem?
Did you try disconnecting the ground on both batteries for a few minutes and see if it resets?
Old Mar 5, 2011 | 11:57 AM
jpr38057's Avatar
jpr38057
Check your fuses. Those are all gem module functions. Which brake switch did you replace? I don't think the brake light switch at the pedal would have anything to do with the abs light coming on.
Old Mar 5, 2011 | 02:18 PM
shelton3's Avatar
shelton3
The issue ended up being the accessory delay relay,that took care of power windows,interior lights,vanity lights , and power mirrors.Still have issue with abs light on dash.The reason I replaced the brake pedal switch was if I press pedal and hold it light stays out until I release pedal.I looked at switch and its multi contact with open and closed contacts,Mercedes uses same type of communication with the abs switch,all speed sensors are good,anything else to check?
Old Mar 5, 2011 | 02:38 PM
jh818's Avatar
jh818
Check your VSS, Vehicle Speed Sensor.
Old Mar 5, 2011 | 05:07 PM
shelton3's Avatar
shelton3
yes ,thats the first thing I replaced.Does the ABS code store and need to be reset,or should it clear out on its own? If I press the brake pedal it will stay out until I release it,then comes on and stays.
Old Mar 5, 2011 | 05:19 PM
jh818's Avatar
jh818
I think if you disconnect the batteries, it resets...unless if there is still an issue out there.
Old Mar 5, 2011 | 08:27 PM
shelton3's Avatar
shelton3
OK will try tomorrow,Thanks
Shelton
Technoblake
Sep 19, 2018 12:08 PM
beckman
May 10, 2013 09:56 AM
briank
Mar 16, 2012 06:01 PM
jlarsen513
Dec 31, 2011 08:02 PM
darinbrooks
Dec 1, 2010 06:23 AM
