Driver's front door sag
Old Mar 9, 2011 | 05:26 PM
bcaughhorn's Avatar
bcaughhorn
ive looked into this. nobody sells pins and bushings. have to go to ford to get a new hinge. i need the lower and was told 40$. havent done it yet
Old Mar 9, 2011 | 05:40 PM
SpringerPop's Avatar
SpringerPop
Thanks for the maintenance reminder, guys.
I just went outside and oiled all my pins.
My doors don't sag, but I oil 'em occasionally.
Pop
Skip1970's Avatar
Skip1970
check the help section at the autoparts store! u know maybe they are not serviceable. dang new disposable trucks.
getting a new hinge wouldnt be painted to match i wouldnt think.. i think you would have to paint them. wow that would be expensive sag fix
Old Mar 9, 2011 | 05:44 PM
bcaughhorn's Avatar
bcaughhorn
Mine just won't get painted
Old Mar 9, 2011 | 05:45 PM
99StrokeXLT's Avatar
99StrokeXLT
I was just out looking at it and to mee it looks like they are riveted pins, or atleast you can't just pull them....then again its dark and i did it on the way to the store without a flash light
Old Oct 21, 2013 | 11:00 AM
TC PSD Excursion's Avatar
TC PSD Excursion
That's what mine look like , there is no retainer clip to pull.
Anyone have any more info on this?
Old Oct 21, 2013 | 11:26 AM
trk98's Avatar
trk98
You can also stick a jack under the door when it's open about 4" and jack it beyond its limits to tweak it back up. Not glamorous by any means, but works for work trucks that don't have any business getting new pins done. Something to consider. Not endorsed by me.
Old Oct 21, 2013 | 11:28 AM
trk98's Avatar
trk98
On my brothers bronco we had to drill the head of the pin before it could be hammered out with a punch. A tip I have for you is to mask the edges of your door and fender with a good thick tape or 2 layers of masking tape. Also be mindful of your windshield when hammering on a punch. Replacement pins typically have the retainer clips.
Sam's The Man
15
Aug 16, 2021 11:53 PM
BainbridgeBrewer
May 20, 2016 11:07 PM
hardknox00001
Paint & Bodywork
Mar 30, 2014 07:32 AM
GreatNorthWoods
Aug 8, 2011 12:28 AM
rocco913
Aug 27, 2010 01:08 PM
