Door-seal Mod
Old Mar 14, 2011 | 01:24 AM
  #46
tdpower's Avatar
tdpower
Originally Posted by timmyboy76
Yup, I cut a slit at bottom of it, to run the tubing upward.
Did you notice any caulk saver or whatever it's called on latch area?
Old Mar 14, 2011 | 01:41 AM
  #47
timmyboy76's Avatar
timmyboy76
if your referring to the "seal" thats only in certain spots of the weatherstripping, then yes...in a few corners, believe to the right of where the doors meet the top, and few other spots. Yeah, just cut a slit before those areas and ran the vinyl, then let slits cure with clear silicone.
Old Mar 14, 2011 | 01:43 AM
  #48
timmyboy76's Avatar
timmyboy76
EPB tube
tdpower, since istarted this thread, i'm gonna high jack it...was hope'n you'd ponder on a thread earlier in the week. I found that you and "pocket" had capped off the EPB sensor, and tossed the tube away, along with plugging up the manifold hole...you still run'n that setup?
Old Mar 14, 2011 | 08:21 AM
  #49
szotty's Avatar
szotty
yeah i came along 2 strips in each seal i just found end of snake and slit and glued the slit
Fordby4
Ford Truck Parts for Sale
May 14, 2017 05:42 PM
Mdc9966
Oct 21, 2015 04:43 PM
cuccs58
Sep 7, 2015 08:26 AM
timmyboy76
Dec 31, 2012 06:56 PM
Truck451
Nov 15, 2009 10:30 PM
