Door-seal Mod
Old Feb 28, 2011 | 11:05 PM
szotty's Avatar
szotty
might be called "caulk saver" dont know ,i just got it from the hardwear store. you need 3/8" if you got local ace or true value or even menards,homedepot just ask when by the caulk deparment, its used to fill gaps before you caulk over em if its too wide or deep for caulk alone. they make couple sizes i think. i think on ebay too, i figured if i was going to do it why not use something that will last, and the latex tubing was way to expensive that was listed in a mod page. think paid 8 bucks all done used silicone spray and wire snake and was done in 30 min. the problem with the reg tubing is as it ages it gets hard and brittle espically in cold weather and i live in northern wis and couple weeks ago my temp read -23 in the truck so i needed the foam to be flexable noise is way down compaied to before
Old Feb 28, 2011 | 11:23 PM
jcrammell's Avatar
jcrammell
I just started having a rattle in my drivers door that is driving me absolutely insane. Might give this a try this weekend. Thanks guy's
Old Feb 28, 2011 | 11:39 PM
frdf250's Avatar
frdf250
Originally Posted by JonathanN
I'm gonna have to try some of this stuff, then... thanks, guys!
First off love your rig. second go to home depot and get roofing material with the stickey backing. costs about 50 bucks i got 2 rolls. i was talking on the phone with mike "Big poppa" today on the way home from Harrisburg, PA.it makes a huge difference. I went from not being able to hear myself think to completly quiet. all i here is my engine, serisouly. i used 4 layers of it. basically just used up both rolls. took all the interior out cleaned the metal with simple green and layed that stuff in, you wouldnt believe how much quieter it got. dynamat is great, but the killll you on the price. its basically the same stuff as the roofing material..
sorry for the hijack
just a thought thouh, if you put the soapy water in a spray bottle it might make it easier, just spray the 3/8" hose as you feed it into the door seal and it should stay lubed up as you slide it in
Old Mar 1, 2011 | 04:42 AM
crum71's Avatar
crum71
1/8 mile Oval Track
I did mine on the passenger side about a year ago. I bought a 100ft of surgical tubing I think for around 30 or so. Anyways, I had problems with running it through(thus only one side done in a year) but it does close off all air/wind noise that it let in before. Maybe will try to do the driver side when it warms up this year.
Old Mar 1, 2011 | 08:15 AM
szotty's Avatar
szotty
might be some foam pieces in your existing molding , i had 4 1 foot pieces of foam through my supercab between bothsides. i made real small slit and pull em out
Old Mar 1, 2011 | 08:25 AM
JonathanN's Avatar
JonathanN
Thanks, man! I love my truck truck, too... yeah, I know that Dynamat is pricey. Eastwood makes some cheaper stuff, but I'm curious about this stuff you're talking about. Have you got a link to something like what you're talking about? I'm really gonna have to look into this!
Old Mar 1, 2011 | 11:31 AM
WA.Ranger's Avatar
WA.Ranger
X2! What are you using?
Old Mar 1, 2011 | 12:44 PM
frdf250's Avatar
frdf250
GAF Tri-Ply Torch App Granule Modified Bitumen Membrane Roll for Low Slope Roofs - 3688100 at The Home Depot
if you go to home depot you are looking for something like that, however it is in a box and has a white backing to it. it worked great!
Old Mar 1, 2011 | 12:58 PM
JonathanN's Avatar
JonathanN
Oh I know what that stuff is... I used some of that on a buddy's house. The only thing is, I would think that stuff would smell up the inside of my truck for awhile. You have a super cab like me, right? Did you do the doors, floor, back wall, and roof when you did it? Know how many square feet were in each roll? This is what I was gonna try instead of the Dynamat... I was just using the name because everybody recognizes it:
Eastwood Thermo-Coustic Sound Deadener Material
Old Mar 1, 2011 | 01:08 PM
frdf250's Avatar
frdf250
Yea i have the xt cab i didnt get a chance to do the doors or roof, hoever i did put a lot where the down pipe comes down the firewall, and i did the back where the bed meets the cab. it is 75sqft per roll. the dimensions are 18ft x 25ft. and i made a mistake they are $50 per roll. i got two and the total was 103.88. lol. sorry i save every reciept. hope this helps!
Old Mar 1, 2011 | 01:12 PM
JonathanN's Avatar
JonathanN
Sure does! I just remember that stuff smelling pretty strong when I used it... I'm sure it'd wear off, though.
Old Mar 1, 2011 | 03:42 PM
PwerStroke99's Avatar
PwerStroke99
mine made a big difference too. I am going to throw in some Dynomat to quiet it down even more
Old Mar 2, 2011 | 08:41 AM
  #28
madcatter33's Avatar
madcatter33
So how long until the smell wore down? I have an Excursion so thats alot of area to cover.......I figure might as well do it when I shampoo the carpet while all the seats are out.
Old Mar 4, 2011 | 09:02 PM
  #29
SpringerPop's Avatar
SpringerPop
Roofers call that stuff bituthane, pronounced "bits-you-thane". It's really good to use instead of felt roofing paper on roofs prone to "ice damming".
Ugly stuff to work with however, as one side is "instant-stick" adhesive. Once it's down, you are not moving it!
Pop
Old Mar 4, 2011 | 09:59 PM
  #30
camodown's Avatar
camodown
If your doors are rattling, you may want to look at the rotating part of the door. They are built with a low friction plastic cover to help stop if from rattling. Mine are completely worn through. Might be worth adjusting your striker too....
