power brake question
Can you fit this set in a ford f100 1956
Someone has ever done that Power brakes FORD TRUCK 1957-1972, F-100, F-250 CHROME - eBay (item 330533709333 end time Feb-28-11 08:44:25 PST) |
Originally Posted by Björn
(Post 10022077)
Someone has ever done that Power brakes FORD TRUCK 1957-1972, F-100, F-250 CHROME - eBay (item 330533709333 end time Feb-28-11 08:44:25 PST) I have a slightly larger booster and sized master hanging on my firewall.. I don't know if that is the right bracket however. the one I used bolted between the firewall and the dash to provide some additional firewall stability (as it will flex when you step on the brake otherwise) Sam |
Email the seller directly. I have dealt with him on a lot of brake setups and he is great about tech support and knowing what is what. If he says it will work, it will work. Good luck.
Originally Posted by sdetweil
(Post 10022753)
it is a firewall mount kit,so yes,you can make it fit.
I have a slightly larger booster and sized master hanging on my firewall.. I don't know if that is the right bracket however. the one I used bolted between the firewall and the dash to provide some additional firewall stability (as it will flex when you step on the brake otherwise) Sam Do you have a picture of the booster on the firewall Sam |
Bjorn,that unit is what I have sitting on a shelf,for a future project.It uses a smaller vacuum unit and is designed, along with the extending bracket ,for trucks that have the firewall mounted brake and clutch master cylinders.The bracket/smaller booster are necessary because of how close the clutch and brake master cylinders are.And teardropty is right,that guy,IrishDave is great to work with.Contact him with your exact info,and he'll sell you just what you need.
1 Attachment(s)
(Post 10022791)
and here is a recent pic, best I have at the moment.. sorry for the sunlight Sam |
Originally Posted by ibuzzard
(Post 10022871)
(Post 10022873)
there is a section in my gallery on installing the fw mount booster and hanging pedals..
the hanging pedal arm, and booster were bought separately from ebay.
the master is the new chrome MCP booster from classic performance products I like this master cylinder cause it has a built-in adjustable proportioning valve, and a brake light switch port too. Sam |
