Battery relocation question
Old Feb 26, 2011 | 11:25 AM
427 fordman's Avatar
427 fordman
I'm getting ready to move my batteries to make room for the york air. Anyway the small ground wire on the drivers side battery is my question. Do I need to increase the size of it to extend it all the way to under the passengers door where the batts will be or will leaving it that size be ok. Here's a pic of it
Old Feb 26, 2011 | 12:44 PM
richdawg's Avatar
richdawg
Whats york air? Don't know much about relocating batts. I think the same wire size would be ok unless you are running a longer length. I think Neal has done the mod and has pics in his gallery.
Old Feb 26, 2011 | 02:06 PM
rodneywar's Avatar
rodneywar
york air compressor it is an engine mounted compressor
Old Feb 26, 2011 | 02:30 PM
427 fordman
Maybe I can just ground that wire somewhere else without taking it all the way to the battery.
Old Feb 26, 2011 | 05:09 PM
Krisx125's Avatar
Krisx125
Thats what i would do! What is the york air used for? Running impact guns and stuff? noo clue what it is...
Old Feb 26, 2011 | 05:29 PM
427 fordman
It will be an on board air compressor. You're right, impacts, air up tires, etc.. Copying what TJ and Cutts did.
Old Feb 26, 2011 | 06:08 PM
richdawg's Avatar
richdawg
I braved the cold and went out to look at mine, that wire is just a little over a foot long and looks like it just gets grounded to the body. I think it would be fine to ground it to the body where you are relocating the battery's to.
Old Feb 26, 2011 | 07:02 PM
427 fordman
I guess I should have looked closer then. I feel kinda stupid. Thanks richdawg. I'm a little laid up and a shop full of other stuff to get done first so just kinda planning right now.
Old Feb 26, 2011 | 08:37 PM
427 fordman
Maybe another dumb question but if that cable just goes from the battery to the body and I move my batts along the frame should I connect a cable to the body or will grounding them both just to the frame be ok?
Old Feb 26, 2011 | 08:50 PM
rodneywar's Avatar
rodneywar
i would ground one to the motor because there wont be any major grounds that will be able to tolerate the starter motor's amperage
Old Feb 26, 2011 | 09:11 PM
richdawg's Avatar
richdawg
X2 on what Ronnie said.
Old Feb 27, 2011 | 12:36 AM
Dave Sponaugle's Avatar
Dave Sponaugle
I would ground both batteries to the engine like they are now.
I would also bond the location that wire was in to the engine.
Your headlight/park/turn signal lights are grounded to the body close to where that wire was attached, possibly at that same screw.
Body panel connections do build up resistance over time as our friend corrosion shows it's ugly head.
So more grounds is never a bad idea.
Old Feb 27, 2011 | 11:58 AM
tjbeggs's Avatar
tjbeggs
I left that cable and wire as it is. I can't remember where the cable goes (Engine or frame) but I left it there and grounded my batteries to both the frame and the engine.
Old Feb 27, 2011 | 12:43 PM
rodneywar's Avatar
rodneywar
the original grounds go to the lower corner of the engine block easiest way to see them is from underneath the truck on each side by the crank pulley
Old Feb 27, 2011 | 12:45 PM
97XLT4X4's Avatar
97XLT4X4
id leave ground wires where they are from the factory
