I think the one on top is a pressure sensor?? The one Im speaking of is at the bottom backside drivers side? I need to replace and think I read you have to drain reservoir. Maxx
You don't have to drain it. Some oil may come out, but if you stuff a rag under the sensor you should be able to catch it. If oil does drain out, it's a good idea to top the reservoir back off after you install the new sensor.
You could be right, don't have my sensor chart handy but Chris got you covered..
Cant find the "link", but i did downloadthe pic, but cant get it posted...anyway, the EOT is on back/driver side, at top, the EOP is on top of hpop, and the IPR is down bottom driver side on back of hpop...guess i cant post attachments..argh
