EOT sensor
Do you have to drain the Hpop reservoir to change the EOT sensor? thanks
I believe the sensor is right there on the top of the HPOP...No need to drain if it is..
I think the one on top is a pressure sensor?? The one Im speaking of is at the bottom backside drivers side? I need to replace and think I read you have to drain reservoir. Maxx
You don't have to drain it. Some oil may come out, but if you stuff a rag under the sensor you should be able to catch it. If oil does drain out, it's a good idea to top the reservoir back off after you install the new sensor.
Originally Posted by ttttmaxx
(Post 10019331)
thanks! I wasn't sure if oil would just pour out once i pulled the sensor...MAXX
(Post 10019331)
Originally Posted by timmyboy76
(Post 10019416)
...guess i cant post attachments..argh
