There was in fact a redesign (pink dot) but it does not account for the huge decline in EGR issues. My belief is something changed in both fuel (mostly) and lubricating oil formulation. Sometime around 2008, the problems started to fade. These days, if you clean the EGR valve, there is not much build a year later.... Unless you are in a high soot / crud climate like I am... even then... I can't wait till the end of the summer to pull teh valve and see what it looks like after a year.
T
IMHO, until the engine warms completely, there is really no call to introduce EGR.
Whaaaat? Internal combustion engines spew more pollutants cold than hot. That's precisely why the EPA includes cold start cycles in its testing. As far as I know, that's when EGR is needed most.
Did you forget why EGR is present? It's not to make your truck run better.
Oh, one more thing. What do you mean by "high soot / crud climate?" Are you suggesting EGR valves clog up sooner in Los Angeles vs. Cody, Wyoming? I bought my truck in Los Angeles, then immediately moved to Cody. I'm afraid breathing clean air could be too much of a shock for it.
