tailgate stuck
Old Feb 24, 2011 | 07:03 AM
jbarefoot's Avatar
jbarefoot
tailgate stuck
I bought a 79 dent and I cant get the tailgate open. The latch isn't hooked to any linkage inside, and I don't wanna ruin it. Is there any way to get it open?
Old Feb 24, 2011 | 07:07 AM
kentucky19's Avatar
kentucky19
Look inside where the handle is there Should be a rod running from each side, Take a screwdriver and pry each one over.
Old Feb 24, 2011 | 07:15 AM
earthquake68's Avatar
earthquake68
^ What he said. You have to squeeze both rods towards the center at the same time. It's not easy, but it can be done. You may need an extra set of hands. Good luck.
Old Feb 24, 2011 | 07:52 AM
kentucky19's Avatar
kentucky19
Sometimes you can do it with your hand but usually your gonna need 2 screwdrivers
Old Feb 24, 2011 | 08:45 AM
jbarefoot's Avatar
jbarefoot
rods missing
one of the rods are missing
Old Feb 24, 2011 | 09:00 AM
Rat77's Avatar
Rat77
One for them may have dropped down out of site. You might need to get a small inspection mirror and a flash light to find it. Thin mechanical fingers are a useful tool in this situation. Good Luck. Be prepared to cuss a little (or a lot) depending on you.
Old Feb 24, 2011 | 09:53 AM
jbarefoot's Avatar
jbarefoot
Thanks for all the advice, this site is by far the best.
Old Feb 24, 2011 | 01:52 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
You can also open the tailgate by inserting a screwdriver into the latches from the sides from inside the box. If you notice there is a small slot to insert the screwdriver for emergency openings like this when one rod is missing when looking at the back of the tailgate at the side latches. Pry one side open then the other etc...
Old Feb 24, 2011 | 02:55 PM
dakonthemountain's Avatar
dakonthemountain
Oye! I had this problem when First purchased Burt. The answers you are getting here a good. Also remember that once you DO get it opened that in order to avoid the same thing happening again (providing that both rods are in fact there ) is to make sure to put the obviously missing nut back on where the rod comes through the latch. It's one of those push on "one way" metal nuts. Sorry I can't remember the technical term for it.. but it stops the rod from falling out of the mechanism again later.
Good luck!
Dak
Old Feb 24, 2011 | 04:11 PM
81-F-150-Explorer
The originals are plastic.
Tailgate Rod Bushing (Keeper): E6AZ-5421952-A
Fits 1973-1986 F-100/F-350, possibly more.
You can get the metal aftermarket ones in the help section of most autopart stores, that seem to last a lot longer, as the plastic ones tend to break all the time.
Old Feb 24, 2011 | 04:27 PM
dakonthemountain
That's it! Thanks for the actual name! Geesh... this getting older is not for the faint of heart or the memory! :-)
Dak
fordbroncodave
1978 - 1996 Big Bronco
Jul 31, 2009 11:43 PM
Totoro
Dec 4, 2008 12:18 PM
bro chuck
1983 - 2012 Ranger & B-Series
Jun 1, 2007 07:04 PM
68 Suburban
Nov 18, 2006 05:15 AM
saultman
Sep 25, 2006 05:40 PM
