1978 - 1996 Big Bronco
tailgate striker and tailgate
Old Jul 31, 2009 | 12:17 PM
fordbroncodave's Avatar
fordbroncodave
where do i get some new tailgate strikers?
how do i open the latch for the driver side striker? somehow it shut when i slammed it and i can't get it open now.
Old Jul 31, 2009 | 03:42 PM
b4hntn's Avatar
b4hntn
Door striker bushings
Help! product #38424 Striker Bolt Bushing Kit, Ford Bronco application 1996-83. $4
Old Jul 31, 2009 | 04:20 PM
b4hntn's Avatar
b4hntn
Is the glass all the way down for the latch to open?
Old Jul 31, 2009 | 05:48 PM
fordbroncodave
yes i can open and close the tailgate just fine, i removed the striker on the driver side so i didn't have to deal with that bull****.
the passenger side striker is starting to get chewed up now so i need some new ones fast, and a way to open the latch on the driver side
Old Jul 31, 2009 | 06:39 PM
greystreak92's Avatar
greystreak92
The strikers should be available through the Graveyard. I have never verified this but I think they are the same as the door strikers. Both latches should open when you pull the release handle even if you closed the latches manually. If they/it doesn't open when the handle is pulled, the suggestion that the window is not all the way down is a viable option. The linkage interlock requires the gate glass be all the way down before the latches will release. The linkage assembly is in the gate just below the handle.
Old Jul 31, 2009 | 07:06 PM
fordbroncodave
thanks. the glass is all the way down. do you think one of the connecter arms or links broke?
Old Jul 31, 2009 | 07:33 PM
greystreak92
It is highly possible. The clips that "lock" the linkage arms in place were nylon and when they get old and brittle they tned to shatter leaving the linkage to flop around and potentially fail.
Old Jul 31, 2009 | 09:21 PM
b4hntn's Avatar
b4hntn
The door striker bushings and tailgate bushings are different. All four come in the kit previously mentioned.
Old Jul 31, 2009 | 11:43 PM
fordbroncodave
i will have to order that from my local carquest then.
random off topic but how do i get a new lock for my center council? the plastic split and one of the tabs stays out in the lock position. it wouldn't open one time so i pried on it until it opened
92 Red F150
20
Feb 10, 2015 12:30 PM
Bayer-Z28
Mar 6, 2014 01:54 PM
danorules
2004 - 2008 F150
Sep 4, 2013 02:10 PM
Tim Hodgson
Jun 10, 2013 04:34 PM
i-w
Nov 11, 2011 07:51 AM
