engine knock
Old Feb 22, 2011 | 03:06 PM
fordmanforlife246's Avatar
fordmanforlife246
engine knock
whats the first step in problem solving an engine knock? you guys are great with helpin me out. pull the headers off? what do you suggest i do. if its simple i just wanna replace the things the engine needs but if the knock has already done damage i wanna drop a new engine in. this is in a 223 engine i picked up for free btw not my 292.
Old Feb 22, 2011 | 03:17 PM
Jetcopterpilot's Avatar
Jetcopterpilot
Start with the simple things... ie; check the oil level, next I would pull the valve cover, and check the valve lash.... See if any of the rockers are loose, or wobbling check for bent push rods. If it is still running, run some block flush through to see if maybe you have a sticky lifter. Check your timing! Start with the cheap and easy stuff first, eliminate the obvious first, then if you need to, start to tear it down. I had a work truck years ago, after checking all of that, I tore it down to find a piston that had split into 2 pieces horizontally so the lower was pushing the upper up, and then the upper would smack the lower half down.. It could also be a stretched connecting rod. but start simple!
Old Feb 22, 2011 | 03:50 PM
fordmanforlife246
okay awesome thanks alot! yes it runs good besides that knock! im gonna pull the covers today and see if anythings loose. sounds like a bad piston. anyways do you guys think this has harmed the engine? (cylinder)
Old Feb 22, 2011 | 04:00 PM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
If you catch them while they still run it usually just needs an overbore like usual.
Run it till it dies then it could very well window the side of your block so you can see the cam shaft wear issue easier.
Old Feb 22, 2011 | 04:06 PM
fordmanforlife246
by overbore you mean by just reshaping the cylinders?
nnnnneeeewwwwbbbbiiieeee
Old Feb 22, 2011 | 06:09 PM
patmedic's Avatar
patmedic
Overbore means you might have to send the block out to a machine shop to have the cylinders bored (made Bigger). Try doing a cylinder balance test on it to determine which cylinder is knocking. Removing one plug wire at a time with insulated pliers and see if the noise goes away on one particular cylinder. Is it knocking at idle or knocking under load or a higher RPM? Definitely start with checking oil level or for anything loose.
Old Feb 22, 2011 | 06:35 PM
shortwide's Avatar
shortwide
My brother bought a 64 Falcon when we were roomates in college and I remember him pulling into the driveway and hearing that distinctive knock that inidicated bottom end issues (bad things). It sounded much like two heavy pieces of wood being knocked together.
Lifter noise, on the other hand typically sounds more like something akin to a snare drum....more "tinny" sounding and a lighter tapping. With lifter noise, you can usually hear it coming from under the valve cover, and can usually make it go away or at least minimize it by adjusting your valve lash.
Exhuast leaks also cause a noise that may resemble "tapping".
I know all of this is terribly unscientific, and based on just personal experience, but it's a start and may give you somewhat of an idea of what you might be dealing with.
Old Feb 22, 2011 | 10:38 PM
Redmanbob's Avatar
Redmanbob
DO NOT RUN FLUSH THROUGH THE MOTOR
it will free up a ton of crap and that residue will get to the bearings. Determining where the knock is coming from is 1st step, crank/top end. Then go from there. Be easier to help when that part is solved.
tvilagomez
Modular V8 (4.6L, 5.4L)
Sep 19, 2014 10:15 AM
dmanshane
16
Mar 20, 2012 12:27 AM
MallardSlayer07
Jan 20, 2008 08:39 PM
ajordan193
Modular V10 (6.8l)
Nov 11, 2006 07:21 PM
knockturnalstorm
Aug 11, 2003 07:46 PM
