what gear ratio
Old Feb 21, 2011 | 11:09 PM
arrowheadfred's Avatar
arrowheadfred
what gear ratio
OK heres the skinny 9''rear / 289/aod/255-70-15 tires . What gear do i need for a every day driver with some get up and go.
Old Feb 21, 2011 | 11:22 PM
das54's Avatar
das54
You need to give us the gear ratio for the 9 Inch.
Old Feb 21, 2011 | 11:29 PM
arrowheadfred
what
Thats what i want from yall !!!! I was told it was 275 but i never heard of this. I need to know what gear i really need. I have only drove it bout 100 miles but it ain't got much go. Not like my 67 mustang
Old Feb 21, 2011 | 11:36 PM
das54's Avatar
das54
Mine is a 2.92 That's kinda short for a 29" dia tire and OD. You'll be running 1581 rpm at 70 mph in OD, 2370 in 3rd. A 3.5 final gear ration might be better 1895 rpm at 70 on OD, and 2841 in D.
Old Feb 21, 2011 | 11:41 PM
arrowheadfred
ok then
What about 370 gears
Old Feb 21, 2011 | 11:42 PM
Horizonblue's Avatar
Horizonblue
2.75 is nice for cruising on the highway, but not much else. With a 302, I think that a 3.5 might be a better all round gearset. Having said that, I don't know enough about the AOD trannys. Depending on the overdrive ratio, you could go to a 3.73 or even a 4.11. Find out the final drive ratio with the overdrive in, and then plug those numbers into a good gear ratio calculator which you can google to find. As well, if you are running a vacuum gauge, you can find out what rpm makes your motor the happiest and use that information as well to find your ideal rpm. Hope this helps. Good luck.
Old Feb 21, 2011 | 11:59 PM
das54's Avatar
das54
The AOD info I found says OD is 0.667 ratio. A 3.70 rear end would give you 2003 rpm at 70 mph.
Old Feb 22, 2011 | 12:03 AM
arrowheadfred
thanks
Thanks i'll sleep on this. I see yall or both new to FTE. Welcome aboard. Here is a pic. for yall to sleep on. LOL
Old Feb 22, 2011 | 04:00 AM
reed1951's Avatar
reed1951
Hey bud, Yeah I researched and searched and then I searched some more and I found 3.70 gearing would be best for my 302/aod setup for daily driving. I have 28" tall 275/60/15 tires in the back. With the 3.70 gear ratio and .67 overdrive, I've found people say that "you can have your cake and eat it too" by having good "get up and go" in town and good gas mileage on the highway.
Old Feb 22, 2011 | 07:21 AM
arrowheadfred
THANKS
Thanks Reed you sold me.
Old Feb 22, 2011 | 08:01 AM
sdetweil's Avatar
sdetweil
and 3.55 wouldn't be bad either.. slightly lower hiway rpms, still enough to spin the tires off the line..
Sam
Old Feb 22, 2011 | 08:12 AM
Doc's Avatar
Doc
My truck has/had (it's in a million pieces right now) a 3.73 with a 302/C6 combo. You ain't gonna win a drag race, but it's got the get up and go, and cruises easily.
Old Feb 22, 2011 | 09:14 AM
rdemilt's Avatar
rdemilt
Depending on what trans you have I would run .
3 spd automatic 3:25's
4 spd O/D automatic 3:70 or 3:89
Old Feb 22, 2011 | 09:36 AM
49willard's Avatar
49willard
I agree with the 3.70. My build is a 383 sbc stroker, AOD and 3.70 with 265-70-15.
kid1994
13
Jun 1, 2012 10:26 PM
95350PS
May 18, 2012 05:57 PM
blowhole
May 8, 2009 11:56 PM
menzfamfour
Oct 18, 2007 06:42 PM
stevtalk
Nov 19, 2006 12:51 PM
