Gears, Gears
Old May 7, 2009 | 09:02 PM
blowhole's Avatar
blowhole
Gears, Gears
How does one tell what gears are in their Ex? Is it printed somewhere, on the axle, on the door? Please advise.
Old May 7, 2009 | 09:26 PM
da X-man's Avatar
da X-man
On the back axle, theres a tag with a code on it. I believe its in the driver door jam as well. Find that code, do a search for the codes and match it. Or wait till somebody else responds with them.
Old May 7, 2009 | 10:05 PM
EXv10's Avatar
EXv10
On the back axle/rear end/pumpkin/third member/differential/final drive or whatever you want to call it there is a tag with 3.73, 4.10 etc. It's on the door jamb also if you want to look it up.
Old May 8, 2009 | 08:43 AM
blowhole's Avatar
blowhole
I will have to go look for it. So the tag will definitely say 3.73 or 4.10? Not just a code?
Old May 8, 2009 | 10:04 AM
kidwagon's Avatar
kidwagon
I had a real hard time finding mine as well. The tag on the differential had some sort of code, not the ratio, and it is blank on the sticker on the door jamb. If you have a 4wd drive you might look at the front axle. I found a sticker on the underside of the front axle that said plain as day 3.73.
Ryan
Old May 8, 2009 | 10:58 AM
X_Hemi_Guy's Avatar
X_Hemi_Guy
Some Ex's have the code on the door/door jamb sticker...some don't.
I agree with kidwagon...I found it easier to look on the front axle if it is 4wd if your door sticker doesn't have the code...lucky me...mine did...
Here's a list of codes for your reference
Axle Type
31 — 3.73 non-limited slip, F-250/Excursion
C1 — 3.73 limited slip, F-250/Excursion
32 — 4.10 non-limited slip, F-250
C2 — 4.10 limited slip, F-250/Excursion
33 — 4.30 non-limited slip, F-250
C3 — 4.30 limited slip, F-250/Excursion
36 — 4.56 non-limited slip, F-250
C6 — 4.56 limited slip, F-250
41 — 3.73 non-limited slip, F-350 (single rear wheels)
D1 — 3.73 limited slip, F-350 (single rear wheels)
42 — 4.10 non-limited slip, F-350 (single rear wheels)
D2 — 4.10 limited slip, F-350 (single rear wheels)
43 — 4.30 non-limited slip, F-350 (single rear wheels)
D3 — 4.30 limited slip, F-350 (single rear wheels)
46 — 4.56 non-limited slip, F-350 (single rear wheels)
D6 — 4.56 limited slip, F-350 (single rear wheels)
61 — 3.73 non-limited slip, F-350 (dual rear wheels)
F1 — 3.73 limited slip, F-350 (dual rear wheels)
62 — 4.10 non-limited slip, F-350 (dual rear wheels)
F2 — 4.10 limited slip, F-350 (dual rear wheels)
63 — 4.30 non-limited slip, F-350 (dual rear wheels)
66 — 4.56 non-limited slip, F-350 (dual rear wheels)
F6 — 4.56 limited slip, F-350 (dual rear wheels)
81 — 3.73 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E1 — 3.73 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
82 — 4.10 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E2 — 4.10 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
83 — 4.30 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E3 — 4.30 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
86 — 4.56 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E6 — 4.56 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
88 — 4.88 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
EW — 4.88 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
G3 — 4.30 limited slip, F-450 Chassis Cab
73 — 4.30 non-limited slip, F-450 Chassis Cab
78 — 4.88 non-limited slip, F-450 Chassis Cab
G8 — 4.88 limited slip, F-450 Chassis Cab
75 — 5.38 non-limited slip, F-450 Chassis Cab
G5 — 5.38 limited slip, F-450 Chassis Cab
GW — 4.10 limited slip, F-450 Chassis Cab
98 — 4.88 non-limited slip, F-550 Chassis Cab
K8 — 4.88 limited slip, F-550 Chassis Cab
95 — 5.38 non-limited slip, F-550 Chassis Cab
K5 — 5.38 limited slip, F-550 Chassis Cab
KW — 4.10 limited slip, F-550 Chassis Cab
Old May 8, 2009 | 11:37 AM
areed's Avatar
areed
Joe do you carry around a Ford/Excursion encyclopedia with you...you always pull this stuff up which amazes me.
Thanks For Being So Organized!
Allen
Old May 8, 2009 | 11:41 AM
X_Hemi_Guy's Avatar
X_Hemi_Guy
Allen,
haha...I just book mark and organize what I feel is useful information so I can easily find it...that's all!
I do have soft copies of my Excursion manual as well as a dealer sales book that has all kinds of useful information...but for the most part...many of these questions come up time and time again so I just started filing them away for easy location when needed is all...but thanks for the compliment!
Joe
Old May 8, 2009 | 12:11 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
If you have a 1999-2007 diesel, you have 3.73 gears. The only reason you have 4.10 or 4.30 gears is if you have a dually.
Gas trucks have a multitude of options...
Old May 8, 2009 | 01:37 PM
blowhole's Avatar
blowhole
Thanks for all the info gentlemen!! This site is awesome. I will crawl under the Ex later this afternoon, most likely the front - and after I look at the door label.
Old May 8, 2009 | 01:46 PM
blowhole's Avatar
blowhole
And since I have a diesel, I assume it is 3.73. But why is that the case? And how would my 6.0L run if I put 4.10's in her??
Old May 8, 2009 | 01:47 PM
Monsta's Avatar
Monsta
Sit. Stay.
Why? ALL diesel Excursions have 3.73's. Period.
Tor' Diesel just said it.
Old May 8, 2009 | 01:53 PM
Monsta's Avatar
Monsta
Sit. Stay.
Whoops... we posted at darn near the same time!
Old May 8, 2009 | 02:04 PM
blowhole's Avatar
blowhole
Or for the universal answer to Why? -- 'Why Not?'
Really, is there a mechanical reason Ford did not offer it with the diesel engine? Wouldn't the diesel set up be that much more able if it had a 4.10? Especially for pulling and heavy stuff??
I know the mod is awesome, but there has to be an explanation for that.....
Old May 8, 2009 | 08:32 PM
EXv10's Avatar
EXv10
My tag was on the rear axle (not the front) and it said 4.10. Lucky me but I wish it was a tru-trac.
