Sponsored by: Real Truck
Trans Fluid Question
Old Feb 21, 2011 | 04:20 PM
LKCKR's Avatar
LKCKR
I have a 2004 F-350 Powerstroke Diesel with the F5R100 Trans. with 120,000 miles. My question is I'm not sure if the fluid in the trans has ever been replaced, would you recommend just changing the fluid or flushing the whole system?
Old Feb 21, 2011 | 05:10 PM
LostinTn.'s Avatar
LostinTn.
Just on a personal note, every time I changed high mileage fluid the new high detergent fluid caused a leak to the seals. If it ain't broke don,t fix it.
Old Feb 21, 2011 | 05:43 PM
LKCKR's Avatar
LKCKR
See, thats what worries me, also any metal particals breaking loose if I flush it out.
Old Feb 21, 2011 | 05:47 PM
ZeroTucker's Avatar
ZeroTucker
Drain the pan, remove it, clean the screen and replace the external filter. This will allow you to see if there is any metal on the magnetic plug and if there is anything in the screen. You will only change 8-9 of the 17 quarts but it will be a start. Only way to do it on high mileage vehicles.
Don't worry about "new high detergent fluid". Use the Ford Mercon SP if you can find it or the new Mercon LV that your truck calls for and you will be fine.
Old Feb 21, 2011 | 08:07 PM
LKCKR's Avatar
LKCKR
OK cool, so if I don't find any thing on the plug, is it safe to flush it or should I avoid the flush and just go with the 8-9 quarts?
Old Feb 22, 2011 | 06:55 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You can only do a flush on a 5R110 (that's the trans you have, also known as the TorqShift) with a heated flush machine. If the machine isn't heated you'll only change about half of the fluid, which is about 8-9 quarts.
LKCKR
2004 - 2008 F150
Nov 29, 2021 11:19 PM
old blue beast
Jul 9, 2013 06:49 PM
buckaroo2219
Mar 27, 2011 07:21 PM
MLCRI$I$ II
Oil & Lubrication
May 23, 2007 02:41 PM
brian.taylor
Sep 30, 2006 01:52 AM
