stumped on rear brakes
Yes it could be. One of the solenoid valves, when activated, shuts off fluid to the rear brakes.
Best bet might be to start loosening pipe nuts to see where you have fluid. Loosen the pipe nut on the pipe to the rear brakes at the master cyl and see if you have fluid there. If so then go to the other end of that pipe (at the RABS module) and loosen the nut there and see if you have fluid there. If yes then loosen the outlet pipe nut at the module and see if you have fluid there. If not try unplugging the electrical plug at the module and see if that helps.
Then the proportioning valve is bad, I would think ( cylinderical part screwed into rear brake port on master cyl.).
