rear brake leak.
Old Mar 29, 2007 | 07:58 PM
90Ford250's Avatar
90Ford250
rear brake leak.
I Know Nothing About Brakes. I Was Wondering If Yall Would Know What Would Be Involved In Fixing This And What Might Be Wrong. And How Much It Would Cost$$
I Have A 90 F250 Straight 6 And There Is Brake Fluid Leaking From The Big Drum Looking Thing That Surounds The Brakes.
Thanks For Your Help.
Old Mar 29, 2007 | 08:05 PM
Bruce R Leech's Avatar
Bruce R Leech
I guess that would be on the rear.
It is no big deal you can get a kit and rebuild it for 10 dollars or buy a rebuilt cylinder and put it on but if the shoes are wet from brake fluid then you need to replace them and it is better to do both sides.
if you haven't done brakes then you need someone that knows how to help you or take it to a good garage.
Bruce
Old Mar 29, 2007 | 08:14 PM
MontanaMan's Avatar
MontanaMan
Yeah ... You should do the wheel cylinder and shoes on both sides. If you are interested in doing it yourself, you can get a chilton's or Haynes manual, which should have pictures to guide you. I did my first brake job at 16.
Another trick is to jack up both rear wheels. Take off both drums. Work on ONE wheel at a time. If you can't figure out how to put things together, use the other wheel as a guide.
90Ford250's Avatar
90Ford250
Thanks For The Reply. Yeah I Forgot To Mention It Is In The Rear.
Im Going To Get A Friend Of Mine That Knows Brakes To Look At It. I Just Dont Want It To Be Big Money..
Thanks For The Help.
Old Mar 29, 2007 | 08:51 PM
Bruce R Leech
if you do it it wont cost to much.
Old Mar 29, 2007 | 09:06 PM
90Ford250's Avatar
90Ford250
just looked on autozone.com and a wheel cylinder is $11.00. will i need anything else beside common tools?
Old Mar 29, 2007 | 10:34 PM
PatsPOS's Avatar
PatsPOS
The only "uncommon" tools you might need is a brake spring tool and a brake adjusting spoon. You'll probably have to adjust the brake shoes away from the drum to get the drum off, and when you get everything back together and the drum back on, you'll want to adjust the shoes so there's a very light drag on the drum.
You might also want to invest in a set of line wrenches, if you don't already have some...they'll make taking the brake line out of the wheel cylinder a WHOLE lot easier. Much less likely to round off the nut.
HTH,
Pat
Old Mar 29, 2007 | 10:40 PM
90Ford250's Avatar
90Ford250
sounds good yall help me out alot. i plan on fixing it this weekend thanks for the help.
Old Mar 29, 2007 | 10:58 PM
quicklook2's Avatar
quicklook2
one of the things that someone with no experience should not mess with is brakes.
take it to a shop.
Old Mar 29, 2007 | 11:20 PM
90Ford250's Avatar
90Ford250
ive got a friend that knows brakes. so i should be able to save some money buy getting him to help.
Old Mar 30, 2007 | 09:07 PM
BigJim191's Avatar
BigJim191
Exclamation
Also remember that there are primary and secondary shoes and don't mix them up...i found out the hard way (don't let a 5 year old help you and let him bring you the shoes from the box) and assembled mine with both primarys on one side and both secondarys on the other and couldn't fingure out why i couldn't get the brake drum back on...just a thought.
Jim
Old Mar 31, 2007 | 08:11 PM
90Ford250's Avatar
90Ford250
Thanks For The Info.
deltajuke
Mar 19, 2013 06:25 PM
bmacky14
1978 - 1996 Big Bronco
Feb 20, 2013 03:24 PM
blee1ash
Mar 8, 2011 11:55 AM
fletus
Jun 11, 2010 06:33 AM
RSLT1
Feb 6, 2008 07:06 PM
