EGR Disconnect
Old Feb 22, 2011 | 10:13 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
P2285 = Injector Control Pressure Sensor Circuit Low Voltage
Probably the ICP sensor is going bad. There's a couple of threads on that in the tech folder: https://www.ford-trucks.com/forums/3...ch-folder.html
Old Feb 22, 2011 | 10:18 PM
StrictlyBusiness's Avatar
StrictlyBusiness
So how much is this going to cost me? Can this cause low power when cold because I am experiencing that.
Old Feb 22, 2011 | 10:34 PM
SteveBricks
FTE Emeritus
I think the sensor can be had for around 100 bucks from partsguyed, who is a site sponsor.
Old Feb 23, 2011 | 12:52 PM
Snowdrift3r's Avatar
Snowdrift3r
Code P2285
Code P2285 Injector ctrl pressure sensor circ low. I found this post:
Yeah I pulled the code P2285. ICP low value. I looked around the internet and there was a TSB:
ICP/EBP Sensor Repair Kit:
Both PowerStroke engines may exhibit codes related to the ICP(7.3: P1280; 6.0: P2285) and/or EBP sensors (P0472). If these codes are present, clear them. Start the engine and wiggle the sensor connector that matches the stored code. If the code returns, replace the sensr connector--P/N 3C3Z-12224-BA for 94-96; 3C3Z-12224-AA for 97-2004. Broadcast Message 1078/SSM #17573.
Old Feb 23, 2011 | 09:38 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Originally Posted by StrictlyBusiness
Well after driving it once with the EGR plugged back in the the CE Light came on. Going to check the code today when I get off work.
What could it be?
Well, I got curious and unplugged mine and here's my experience. No significant changes to the way it ran except maybe a little rougher idle on cold start and a little less power until it warmed up. made a 15mi trip (each way) to work (mostly 55 and 65 mph). shut down for 15 min. Restart, ran well, check engine light came on when accelerating up to speed first time on return trip and stayed on. When I got home my mileage on the dash display was 2.4 mpg higher than normal for this trip. Broke out the scanner (Innova 3150) and got the following report:
Date: 20 Feb 2011
Year: 2006 (FX4 CC King Ranch No Mods Not sure what PCM flash)
Make: Ford
Model: F250
Engine: 6.0L
VIN:
License:
Mileage: 132524
Stored:
P0403 Exhaust Gas Recirculation Control Circuit
P0405 Exhaust Gas Recirculation Sensor A Circuit Low
Pending:
Enhanced: Ford KOER DTC
P1408 Exhaust Gas Recirculation Flow Out Of Self Test Range
P1464 A/C Demand Out Of Self Test Range
MIL ON
Misfire Monitoring Complete
Fuel System Monitoring Not Supported
Comprehensive Component Monitoring Complete
Catalyst Monitoring Not Supported
Heated Catalyst Monitoring Not Supported
Evaporative System Monitoring Not Supported
Secondary Air System Monitoring Not Supported
A/C System Refrigerant Monitoring Not Supported
Oxygen Sensor Monitoring Not Supported
Oxygen Sensor Heater Monitoring Not Supported
EGR System Monitor Complete
DTC for which Freeze Frame was Stored P0403
Calculated LOAD Value 55.69 %
Engine Coolant Temp 159.80 °F
Intake Manifold Absolute Pressure 37.50 inHg
Engine RPM 1470 rpm
Vehicle Speed Sensor 7.46 mph
Intake Air Temperature 80.60 °F
Air Flow Rate Mass Air Flow Sensor 13.20 lb/min
Auxiliary Input Status / Power Take Off Status Not Active
Time Since Engine Start 373 sec
Commanded EGR 0.00 %
EGR Error 0.00 %
Fuel Level Input 94.12 %
# Warm-ups since DTC Cleared 22
Distance since DTC Cleared 396.45 mi
Barometric Pressure 29.53 inHg
Control Module Voltage 14.03 V
Accelerator Pedal Position D 39.22 %
Accelerator Pedal Position E 44.71 %
Accelerator Pedal Position F 33.73 %
Plugged EGR back in and erased codes. So I learned if I just unplug it, I'll be driving an very nice truck with the MIL shining at me. not liking that. Might have see a small increase in mileage (if you believe that lying gauge on your dash) would have to check on that further. More fussy on cold start which is a small annoyance already. So for me, it's staying plugged in until I can try some of the other stuff that goes along with disabling EGR that I've been reading about in the TECH Folder. Not sure why I got the code for A/C demand, I never saw that one before or since. Kinda weird. Also if you notice, there is a code for EGR flow. seems like that might be hard to get around without some software tweaking.
Old Mar 2, 2011 | 10:14 PM
Javo's Avatar
Javo
It's funny you posted this thread when you did because I was wondering about unplugging my EGR last week due to problems this system "seems" to cause. So I cleaned (it was REALLY gummed up) it as good as new, installed it and then unplugged it the next morning. So far my truck actually seems to be running a little better, maybe it's just me. I've driven it for three days and no CEL.
What i'm really interested to see is if my mileage improves as mentioned earlier. My truck only gets about 12mpg, so a 2mpg increase would be nice (especially now days!). I filled my tank two days ago and when I do my next fill I'll do a manual mpg calculation since I don't trust the lie-o-meter. I'll post those numbers for you when I do.
bykr
Jun 24, 2016 10:56 AM
KDAVID1
Mar 27, 2015 09:56 PM
daxk1
Arizona Chapter
Sep 27, 2010 05:53 PM
Bert01F150
3.8 & 4.2L V6
Jun 29, 2009 10:23 PM
akula22
Jan 25, 2005 01:40 PM
