EGR Disconnect
Old Feb 20, 2011 | 09:30 PM
StrictlyBusiness's Avatar
StrictlyBusiness
EGR Disconnect
I have an 04 6.0 Liter and I was wonder can I disconnect the EGR without disconnecting the throttle plate?
I already did it and the truck seems to run fine, but i'm just wondering if it can have any negative effects.
Old Feb 20, 2011 | 10:03 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Yes, it can have negative effects.
What are you hoping to accomplish by disconnecting the EGR valve?
Old Feb 20, 2011 | 11:34 PM
alexisvfd's Avatar
alexisvfd
is ur cooler gone bad or anything
Old Feb 21, 2011 | 03:46 PM
StrictlyBusiness
I just did it because it was easy and everything I have read about the egr system has been negative
What are the negative effects of disconnecting it? Should I reconnect.
I just bought the truck two weeeks ago. Only thing I have done is change the fuel filters. It has an edge juice programmer.
Old Feb 21, 2011 | 04:12 PM
smokersteve's Avatar
smokersteve
I hate to say this, but you should take the edge off. it is not good for the transmission.
I have my egr valve unplugged. I do it to stop the exhaust flow. I do not have any issues from unplugging it..
Old Feb 21, 2011 | 05:52 PM
StrictlyBusiness
The truck has 75,000 miles and the transmission shifts very smooth. The dealership I purchased the truck from put me in contact with the original owner and he told me that he rarely ran the truck in anything besides the stock/0 mode. The edge doesn't affect the transmission if I run it on 0, right?
I plugged the EGR back in until I get more input.
Old Feb 21, 2011 | 06:02 PM
mil-spec's Avatar
mil-spec
egr
How is it any different than having it shut off in a program. My programs from innovative shut the egr off. And everything has been working fine.
Old Feb 21, 2011 | 06:07 PM
StrictlyBusiness
Still haven't seen anyone post a disadvantage to unplugging it?
Old Feb 21, 2011 | 06:49 PM
Young Gun's Avatar
Young Gun
On certain strategies the fan doesn't cycle properly with the EGR vavle unplugged.
I hope you are monitoring EOT and ECT with your Edge. Clogged oil coolers cause the EGR cooler to fail
Old Feb 21, 2011 | 07:11 PM
smokersteve
I use to have a platinum. The edege still effects the truck no matter what setting you have it on. The "0" setting is STOCK HP setting, not stock TUNING. "0" is edge tuning at STOCK hp. The edge will hurt the trans when ever your foot pushes the engine to send more than STOCK HP to the trans. So.... you can have it on level 5 (or 6 if you buy it) and never pass STOCK HP level with your foot.
I was on a long straight consistent hill one time with the platinum. I held my foot at 50mph and was at "0" level selction on the edge. I then gradualy increased the power level (0 -> 1 -> 2 -> 3...) and as I did this I feelt an increase in power out of the truck.
You are not chaning the tuning of the engine with each # level selection. They are all the same tuning BUT... each level has a different throuttle map input.
Old Feb 22, 2011 | 05:01 AM
StrictlyBusiness
Well after driving it once with the EGR plugged back in the the CE Light came on. Going to check the code today when I get off work.
What could it be?
Old Feb 22, 2011 | 08:15 AM
402xjeeper's Avatar
402xjeeper
My 04 will trigger a cel after a long time with the EGR unplugged, I run a machined aluminum slug in place of the EGR valve, and keep the old EGR valve plugged in zip tied to the intake elbow. Remove the butterfly plate from the intake wether or not you dissconnect the EGR. on 04s the throttle body on the intake draws exhaust in through the EGR system, on 05 and later 6.0s the scoop in the exhaust serves the same function.
Old Feb 22, 2011 | 08:55 AM
broncoformudv's Avatar
broncoformudv
Check your intake elbow to see if there is actually a throttle body or not. Some 03-04 trucks have what looks like a throttle body but there is not one on there. they still have the connections but there is nothing in the throttle body. Guess they put the connections on there so there were no lose connections on the electrical harness.
Old Feb 22, 2011 | 03:45 PM
402xjeeper's Avatar
402xjeeper
03 motors had the dummy throttle body, some early 04 trucks had 03 motors.
Old Feb 22, 2011 | 10:02 PM
StrictlyBusiness
Well after pulling the code at a local auto parts store it was p2285.
what does this mean?
