Battery disconnected--relearn?
Old Mar 27, 2015 | 09:39 PM
KDAVID1's Avatar
KDAVID1
Should I have to do a relearn after having batteries disconnected for about 15 minutes?
2006 F350 4X4 Mishi 200° tstat, IPR EGR delete/up-pipe
Old Mar 27, 2015 | 09:47 PM
mhoefer's Avatar
mhoefer
You can, if you want, but you don't have to. If you want to, you cycle to on with the key, wait 20 seconds, then to off for a minute, then repeat 4 times, the start and wait and let idle 15 minutes, then drive for atleast 20 minutes. If you get a code drive sequence then you have to keep going.....
Old Mar 27, 2015 | 09:56 PM
KDAVID1's Avatar
KDAVID1
Thanks. Don't think I will. Was wondering if it was needed as I got a ton of codes when I startedmit up. I figured it was from disconnecting everything and having batteries un hooked.
KDAVID1
Apr 1, 2015 10:12 AM
KDAVID1
Mar 30, 2015 03:16 PM
oceansun1984
Jun 10, 2012 04:02 PM
firemedic116
Jun 3, 2010 01:37 PM
wib714
3.0L V6
Dec 19, 2004 01:39 PM
