New tranny, now wont start. Help?
Old Feb 20, 2011 | 03:28 PM
jbirdsvt's Avatar
jbirdsvt
I just finished putting in my "new-to-me" C6 and everything seemed to go fine with that. Problem is, now it wont start. It doesn't turn over at all. I feel like it has to have something to do with the NSS, but what? It's the same switch that was on the previous tranny, and there's only one way to put it on. I just don't see where i could go wrong with that. Any ideas?
Also, i don't know if it's relevant, but i also can't feel the detents the way i could before. I have to pull the shift lever (on the column) from about 1:00 to below 3:00 before it feels like it "falls" into a gear.
Old Feb 20, 2011 | 03:38 PM
ri_truck_guy's Avatar
ri_truck_guy
Sounds like it could be an adjustment issue. Try disconnecting the linkage and make sure the tranny is fully in park by hand, then try to start it and see what happens.
Old Feb 20, 2011 | 03:57 PM
jbirdsvt's Avatar
jbirdsvt
So try that with the NSS still on there? I tried taking the NSS off completely and rotating the ring inside it, but no matter where i put it, it still didn't start. Also, just so i'm sure, park should have the lever all the way towards the front of the tranny, right?
Also, i just went out and tried to jump the solenoid and it will turn over that way. It wouldn't start, but it did turn over. That shouldn't have anything to do with the NSS should it?
Old Feb 20, 2011 | 05:50 PM
6fifty_f1fifty's Avatar
6fifty_f1fifty
Did the tranny come off of a truck? Car automatics had a reverse shift pattern if I'm not mistaken.
Old Feb 20, 2011 | 08:24 PM
jbirdsvt's Avatar
jbirdsvt
Yeah, the new tranny was originally in a Bronco. It was mated up to a 302 until the day I got it.
Old Feb 20, 2011 | 08:48 PM
ri_truck_guy
The shift lever should mount from the bottom and and park position is to the front of the truck. If it starts with the linkage off, you need to look at linkage adjustment next. If it doesn't start, there's an adjustment to the NSS that involves a small drill bit through an alignment hole on the front of the NSS.
ORmetalworker
Dec 16, 2014 12:25 PM
toeightfo
Feb 17, 2014 08:02 AM
thbowen
20
Jun 7, 2009 08:36 PM
00jimmyd00
16
Aug 19, 2005 07:43 PM
jbirdsvt
Jul 18, 2005 10:37 PM
