Commercial Diesel
Old Jan 19, 2010 | 08:19 PM
Danspeed1's Avatar
Danspeed1
Commercial Diesel
Took a trip this past week in my 85 F-350 6.9L DSL. Along the way I needed to stop and fill up. This is something that has happened to me a couple times already and I am beginning to find it very annoying. So I stopped at a Diesel truck station which had good fuel prices and went to fill up. When I pulled out the pump handle I immediately realized that the nozzle wasn't going to fit my truck. It was the larger commerical nozzle. So I hung it up and went inside to ask which pump would fit my truck. Guess what... they didn't have one. They had regular gas pumps but no diesel. So i continued on my way until I found an overpriced station that met my fuel nozzle needs. This is not the first time this has happened. One day I hit about 5 stations that didn't carry diesel, and then one that had 3 pumps for commercial trucks... thankfully they had 1, yes only 1 pump for cars/rv's. Has anybody done a fill tube conversion on there truck so it is able to accept the larger commercial nozzle?
Dan
Old Jan 19, 2010 | 09:20 PM
Franklin2's Avatar
Franklin2
I did mine. I took the clamp off and the 3 bolts, and took the filler assembly out of the side of the bed. Next thing I did was yank and pull till I got the smaller rubber hose out of the middle of the larger hose. I then put the metal filler in a vise, and took a hammer and sharp chisel and worked around the inside of the filler, cutting away the hole sort of like a old time can opener.
The large nozzles now fit ok, but you can't open them up wide open. I don't know about you, but my diesel and most other Ford diesels have the filling problem, and even the smaller pump nozzles give me trouble. What I am going to do next is take the vent fitting out of the top of the tank, screw a 1/2" 90 degree pipe fitting into the rubber grommet, and run a larger vent pipe off that and hook it to another 90 degree fitting that I am going to weld into the metal filler pipe near the top. That should help the air get out of the tank better, and stop the slow filling.
Old Jan 19, 2010 | 11:52 PM
Danspeed1's Avatar
Danspeed1
Yea, I do already have that same problem. I have to hold the pump below the first notch or it sprays out at me. I wonder if opening up that pipe will help it at all for the smaller pumps?
DG
Old Jan 20, 2010 | 09:54 AM
LCAM-01XA's Avatar
LCAM-01XA
I have the harpooned tanks on my truck, I fill up at big truck pumps more often than I do at car diesel pump, I can tell you that 1/2" vent from top of tanks ain't large enough to run the pump at full bore, actually even car diesel pumps shut off rather quick if I run them wide open. I think it ain't so much as the vent is too small, as it's the darn fuel foams up too much cause it has to run down a long hose, and not straight into the tank like it does with a big truck... Regardless, make sure your vent hose is at least 5/8" ID, 3/4" would be even better, I'm redoing mine in 3/4" when I get around to dropping the rear tank for replacement.
Old Jan 21, 2010 | 06:34 AM
magusjinx's Avatar
magusjinx
Thinking of flatbedding mine ... Might put a crossbed aux tank in ... That just has a cap on 2 inch riser ... No worries then ... Fill up as fast as I want ... And where I want ...
Old Jan 21, 2010 | 11:51 AM
LCAM-01XA's Avatar
LCAM-01XA
Installing a on-bed tank reduces the bed's usable space quite a lot, so you may wanna reconsider that... Also, what are you going to do about the fuel level sender unit so your fuel gauge works properly?
Old Jan 21, 2010 | 08:53 PM
Franklin2's Avatar
Franklin2
Have you looked at the DOT approved aux tanks? Those things are not cheap.
Old Feb 9, 2011 | 09:51 AM
Lukes66's Avatar
Lukes66
I know I am bringing up a thread that is a year old, but I want to know if Franklin2 ever put in a 1/2 inch vent on top of the tank and how that turned out. I want to run my tanks on my diesel F250 with just a single vent on the top of the tank. If half an inch isnt enough vent, how to you make it bigger, drill it out and screw a bigger fitting in?
Old Feb 9, 2011 | 08:00 PM
Franklin2's Avatar
Franklin2
It worked out well. No, I cannot run the nozzles full flow with the 1/2" vents, but it's so much better than the stock system. If I use a big truck nozzle, I have to regulate it by hand, but it's filling plenty fast for me. I can put the filler on the 1st automatic notch on the smaller car type pumps. I am very happy with it.
I am not sure how you would get a fitting and pipe bigger than 1/2" on the rear tank. I had some copper pipe with sweat 90's on it laying around, so I used that, the OD of the sweat 1/2" 90 just fit into the rubber grommet, and I used a little bit of permatex 1 sealer around for insurance against leaks. When I lowered the bed back down on the frame, the vent pipe was trapped between the top of the tank and the bottom of the bed, with no room left for anything bigger.
Most people modify the metal filler neck with a fitting to install the vent line, but I just got a length of hose, and wire tied it in a large loop going up into the cavity behind the bedside, and then attached a little bit of window screen on the end of the hose to keep bugs out of the pipe.
Old Feb 20, 2011 | 09:27 PM
Lukes66's Avatar
Lukes66
Now that I have my bed off I have been thinking more about this. I am thinking I will do exactly what Dave did with the half inch 90 into the rollover valve opening, but I am also considering drilling another hole for a second half inch vent.
I know there must be some clever way to solve this so I am going to post up and see if someone a little brighter than me has any better ideas than adding a second vent.
I also want to eliminate the filler vent hose, and chisel out the filler neck to take a semi nozzle.
What if I tapped in a 3/4 inch vent at the base of the fill hose where it goes into the tank, would that help? I have seen some pretty elaborate fuel vapor plumbing setups but I want to keep it simple if possible.
I spent 45 minutes in 5 degree temps with 60 mph winds a few weeks ago trying to fill this thing up and I thought I was going to die! So I am now determined to solve this once and for all.
