Company looks like new outfit, or at least I aint heard of them. Either way, I wonder how streetable that combination would be. I have always wondered about a mechanical 7.3 DIT just in case someone lets loose an EMP...
I don't know how long they have been around but I like what there doing.This has beed dicussed a few times on here.I would like to see how the engine will work out with day to day use.
That actually pisses me off. Do they really think a pump is worth $17k?? Come on............ I *might* consider $5k. That's just stupid.
there is littel more then a pump to do this mod
Front Cover - aluminum $3,650
Front Cover intermediate plate - steel $160
Injection Pump adapter plate - aluminum $295 Injection Pump $6,800 Injection Pump Hub $138
Injection Pump Gear $395
Mid mount support bar $25
Injection Lines, 8pcs $880
Injectors $2,720
Hold down clamps $320
Injector adapter sleeve - aluminum $400
Fuel transfer Adapter plate - aluminum $215
Fuel Transfer Pump $475
Fuel transfer pump coupler $20
Fuel Transfer Drive Hub $138
Star drive $6
valve covers $675
injection nut cover plates $240
valve cover injector seals $24
valve cover o-ring $36
Grand Total $17,612
but your in luck..the pump alone is a littler over the 5k you was hoping for....
at the same time a agree with ya..with todays tuning and some good hybrids...700-800 HP isnt that hard to get any more...i dont see any needs for higher HP then that...
