Washed Engine - now engine misses
Old Apr 15, 2009 | 12:35 PM
Dragracer_Rob's Avatar
Dragracer_Rob
Hello all,
I have a 98 Expy and washed the engine compartment. The engine now misses pretty consistently, all rpm ranges. Concurrently had a battery go bad and the starter died too, not sure if they are related at all. Not throwing any codes. Took the truck to the shop and they checked all the coils and replaced the dead starter, all the coils tested good. What am I missing?
Thanks for looking.
Rob
Old Apr 15, 2009 | 03:11 PM
mikecox1's Avatar
mikecox1
You likely got water in one or more of you COP boots. Dialetic grease is your friend in this situation. Same thing happend to me a couple of years ago after washing my engine.
Old Apr 15, 2009 | 03:16 PM
pops_91710's Avatar
pops_91710
I agree with Mike, you need to dry out each boot before they begin to corrode and use some dielectric grease inside each boot. Corrosion will quickly take them out! Been there, done that!
Old Apr 15, 2009 | 09:11 PM
alloro's Avatar
alloro
One or more of the boots on the bottom of the coil has a split in it. Water gets into the split and acts like a conductor allowing the spark to jump to the side wall. Your best bet is to grab a set of replacement boots for about $25 and dielectric grease. Replace the boots and use the DG inside them before you reinstall the coils and you'll be good to go.
PPrash
Dec 27, 2016 01:12 PM
ol'yeller
Escape & Escape Hybrid
Sep 12, 2015 11:18 PM
haven1950
Jul 6, 2014 11:14 PM
StuckonFordTruck
Modular V8 (4.6L, 5.4L)
Jan 24, 2013 07:12 PM
2012 SD Snowbuster
2004 - 2008 F150
Jan 8, 2013 06:58 PM
