The connection cleaner did the trick i have my revers lights working now, but now a new problem has arisen my indicator doesn't work at all! it barely worked before. the flasher doesn't seem to be getting power anymore...well some times it does then stops the hazards work fine..i'm stumped
well i popped a fuse and spliced some wires and got the indicators to work, but now my fuel and oil gauges don't work . i just barely connected the fuel gauge too, could i have killed my float?... where is the oil pressure censer?
it magically came on::shrugs:: i tracked the issue to the hazard lights the switch isn't fully disengaging..
Reason: update
