reverse lights
Old Nov 4, 2015 | 05:23 PM
tjc transport's Avatar
tjc transport
i ain't rite
reverse lights
truck is an 02 diesel with auto trans.
has anyone added extra reverse lights and hooked them up to a separate toggle switch AND the stock switch?
i want to be able to use the reverse lights, (stock lights and 3 sets of leds) with both the stock switch but also with a switch the dash for rear work lights.
case in point: with the salt spreader in the bed, there is no real way to see the broadcast pattern except to turn it on and then get out and look. this wastes salt. by turning the lights on while i am moving i will be able to see how far i am slinging, and how much is coming out.
i am not sure if turning the reverse lights on while the trans is in any gear besides reverse will hurt anything though.
Old Nov 4, 2015 | 10:42 PM
SARDiverDan's Avatar
SARDiverDan
I use back-up buddy lights and they have a switch on them so you can turn them on as work lights when you are behind the truck. I would imagine you could rewire this switch to be able to turn it on from inside the cab. Electrical rigging is not my strong suit but I am sure someone on here would have an easy solution.
Old Nov 5, 2015 | 12:39 AM
Rikster-7700's Avatar
Rikster-7700
Just tap off the reversing light circuit and install a separate switch in parallel from the cab (run both sets of wires to the LED lights) using a constant hot from the fuse block (can be a switched feed that can only be turned on if your key is turned on also if that suits your need better). This way they will turn on if you have it in reverse or have the switch turned on, or both.
The only issue with this is that your reverse lights (stock) will turn on with the switch too. If you don't want this then a relay that is set to close its contacts (coil receives a 12v signal from the stock circuit too) when the stock reverse lights are on tied in between the two feeds will stop your reversing lights turning on with just the switch.
I hope this makes sense? It's been a long day and j am about to head to bed! I will re-read when I get up to make sure it's not just a bunch of random words put together.
Old Nov 5, 2015 | 12:53 AM
scotttahoe's Avatar
scotttahoe
Just did this to a buds truck and mine is next.
I have LED's under the trailer hitch and when you shift it into reverse the LED's and factory R lights come on.
To wire those up to a switch so you can turn them on when in drive or park you want to run a relay.
Relay # 30 + power supply with inline fuse to relay.
Relay # 85 to ground.
Relay # 86 in cab switch power to relay.
Relay # 87 to (number of places) 1. To the trucks fuse box for the reverse lights. 2. Down at reverse switch on transmission. 3. Run wire all the to the back of the truck into the trailer 7 way plug reverse wire (think it's purple or orange. Use test light) and tie into the backside of that.
Old Nov 5, 2015 | 05:21 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
My son uses a wireless remote switch for all of his LED lights. Pretty slick setup! He can turn them all on or just certain ones from over 50 yards away. You need welding glasses when they are all on, yet they hardly draw any amps.
Old Nov 5, 2015 | 06:25 AM
tjc transport
i ain't rite
the led's are already mounted under the bumper and tapped into the truck lights. the overhead "takedown lights" in the whelen led bar are tapped to battery power through a relay and circuit breaker with relay trigger power coming from the fuse box through a switch inside the truck.
what i want to do is run a wire from the relay to the truck/under bumper led's.
my main question is if putting power to the reverse lights while the truck is in forward gear will cause issues with the trans.
Old Nov 5, 2015 | 06:36 AM
ExPACamper's Avatar
ExPACamper
Are you asking if apply 12v power from a different source to the truck's reverse light circuit when it is off will cause any problems, assuming it is connected to the reverse sensor of the transmission?
One option is to use a DIODE in the stock reverse light circuit, between the stock circuit and where you apply power via the switched relay.
Diodes only flow in one direction and will prevent a backfeed on the stock circuit.
Old Nov 5, 2015 | 12:34 PM
scotttahoe's Avatar
scotttahoe
When we wired up my buddys truck we ran the wire from the relay all the way back to the 7 pin reverse wire and has had no issues. I don't want to run a wire that far back so I'm going to tap in to the reverse wire on the trans switch. Shouldn't be a problem as all that does is to tell the lights to come on.
Old Nov 5, 2015 | 04:37 PM
tjc transport
i ain't rite
good, that is what i was looking to hear.
i prefer not to splice into stock wiring harness in trucks that work in the winter, the salt water off the roads tears things up.
KC Steve65
Oct 8, 2016 11:30 AM
JRD761
Electrical Systems/Wiring
May 8, 2015 01:58 PM
mikeyt4e
Mar 7, 2015 05:12 PM
CCtaker
Jan 27, 2009 06:55 PM
buckshot047
Apr 21, 2007 05:32 PM
