Reverse lights still not working
Old Feb 18, 2011 | 11:32 PM
FordmanShane's Avatar
FordmanShane
Lightbulb Reverse lights still not working
So the story on this truck is its a 75 jerry rigged high boy i bought off some hill billys down south.. im slowly restoring and modding the ol girl.
For the longest i have had my reverse lights hooked up to a toggle switch and i was wondering how i can get the reverse lights working right, i was told the issue can be in the column or a toggle switch on the C6..
I have replaced the column and internals so that's ruled out, what can be the problem? I'd like to get them working right, do you know anything subject?
your 2 cents are welcome..
Old Feb 18, 2011 | 11:54 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I think the reverse light sw is on the column with the safety neutral on a 75? Its a small white sw bolted to the side of the column under the dash.
78/79 they were both moved to the xmsn, I think....
Hang in there someone, will chime in on this.
Old Feb 19, 2011 | 06:53 AM
ranger429's Avatar
ranger429
Your correct77&79.
What year column did you put in the truck?
Old Feb 19, 2011 | 08:02 AM
77&79F250's Avatar
77&79F250
Thanks for checking me "correct", BTW you still have some awesome trucks!
Old Feb 19, 2011 | 08:15 AM
ranger429's Avatar
ranger429
Thanks.
Old Feb 19, 2011 | 12:01 PM
FordmanShane
ranger429 thanks for pointing that out the turn signal switch came from a 75 2wd.
77&79F250 i know exactly what your talking about thank you, its a sunny day ill see what i can do.
Old Feb 19, 2011 | 12:15 PM
ranger429's Avatar
ranger429
The turn signal switch isn't in the equation Shane. What year column did you use when you replaced it?
Old Feb 19, 2011 | 12:58 PM
FordmanShane
Ranger429 the column came from a 75
The neutral safety switch works the wiring seems untempered with in and under the dash, connections look good..
Old Feb 19, 2011 | 01:09 PM
ranger429's Avatar
ranger429
I'm not sure how to adjust the NSS on the earlier models. Don't know if you have tried that but a search here would probably pull up a thread on it.
Old Feb 19, 2011 | 01:44 PM
FordmanShane
Good thing you mentioned that i game the search a second chance on google this time and some folks were mentioning fuses.. and welp i found a blown fuse!!! im heading to pick n pull now haha
Old Feb 19, 2011 | 03:08 PM
FordmanShane
Cool update
I replaced the fuse and still nothing
Old Feb 19, 2011 | 07:25 PM
FordmanShane
Smile one reverse light working
I now have one reverse light working i found a 77 2wd auto with the NSS in the bed of the truck i picked it up just to see if it was the existing NSS causing the problems. connected it up and put her in R and one light was lit!
my neighbor stopped by with some connection cleaner and called it a night.
thank for the help fellas..
Old Feb 19, 2011 | 08:42 PM
77&79F250's Avatar
77&79F250
Sounds like you are about there, let us know the final outcome.
Old Feb 19, 2011 | 09:05 PM
One79one71's Avatar
One79one71
Yeah thats a problem in our trucks, Ford didnt believe in applying dielectric grease to connections, so expect to have to clean connections and allpy grease...Personally, i have no backup lights atm, since mine was mounted on the column in the engine compartement at the shifter linkage and since the 3 on the floor conversion, it has just been dangling there... Actually on the 79 that was stolen from me I had a bad backup switch and instead of paying the high cost of a new one, my broke self SAWED the switch open carefully, fixed the connections and resealed it I readjusted the clearance to the thing that pushes the switch and it worked like a charm for years!
P.S Total cost was 1c....The penny i superglued to the shifter linkage where it touches the switch!!!!!!
Old Feb 20, 2011 | 07:36 AM
qbenplaya00's Avatar
qbenplaya00
mech said on mine was the neutral safety it acts as both... and i had to replace it on my 74... also didnt help wires were old and brittle and bad ground. so def check all those.
