351 w knock
Old Feb 18, 2011 | 11:10 PM
mitchelljohnson1201's Avatar
mitchelljohnson1201
351 w knock
Hey got a 93 ford f 250 with a 351w and about a week after putting on headers i developed a knock in the engine. the motor hads about 171,000 miles but plenty of oil pressure and of course oil. I cant hear it unless i get on the throttle pretty hard either. any ideas?
Old Feb 19, 2011 | 03:41 PM
jimbbski's Avatar
jimbbski
Are you sure it's a knock? What does it sound like?
Having just installed headers are you sure that the headers are not just hitting some part of the vehicle?
Old Feb 19, 2011 | 05:48 PM
bashby's Avatar
bashby
did you eliminate the egr when you did the headers? Could it be detonation you're hearing?
Old Feb 19, 2011 | 08:06 PM
fluffykins's Avatar
fluffykins
are you sure its not a leak?
Old Feb 19, 2011 | 08:39 PM
mitchelljohnson1201
Im sure its not an exhaust leak becouse it only happens when there is a load on the motor, which brings me to the egr sensor. im buying the eliminator kit but i dont know what all to get. so far I got the block off plate and the plug in connector, not sure if i need the actuator risistors or if I need the termanal leads either? anbody know?
Old Feb 20, 2011 | 08:35 AM
bashby's Avatar
bashby
If you think it might be detonation, retard your timing and see if it goes away. Eliminating the egr will increase the chance for detonation.
Old Feb 20, 2011 | 02:45 PM
restoringmy46's Avatar
restoringmy46
I had a motor with headers to the samething. The knock sounded just like a rod knocking in the motor. It ended up being a header leak. The header had a bend in it but you could only tell by putting a striaght edge on it. Hope this is it and not the motor.
Old Feb 20, 2011 | 06:54 PM
mitchelljohnson1201
Exhaust leak!!. well i guess double-triple checking the header bolts paid off. had a couple of loose bolt that i had missed the first time i tighten them down.thanks alot
Old Feb 21, 2011 | 03:23 AM
fluffykins's Avatar
fluffykins
keep checking them too cuz they loosen after you first put them on
Old Feb 25, 2011 | 11:55 AM
mitchelljohnson1201
ok thanks for all the help
mdr617
Apr 1, 2011 01:29 PM
Speedjester
Oct 1, 2010 12:29 AM
blloyd
17
Nov 19, 2007 05:59 PM
cscottbookseller
Engine Swaps
Aug 1, 2005 10:04 AM
V8 Andy
Oct 21, 2004 12:57 AM
