Hi,
i have a problem,
my truck with the 351w stands for a long time, about 1 year. All fluids were removed.
Now i fill up the oil, and try to run the Engine, but i hear a metallic knocking out of the oil pan. And the oil pressure is very low.
Well don´t tell me it´s the oil pump
Sometimes the oil pressure gauge is in the middle of "normal", whatever temperature the oil is.
Mainly the "knocking" sounds very badly, anyone an idea ?
If all the fluids were drained and it sat for a year, Did you prime the engine before you started it?
The knocking sounds like it could be a rod and or bearing or maybe a wrist pin.
hey, no i don´t prime, sorry for the next question but, what is this, i don´t know what you mean.
It sounds to me like a bearing from the camshaft or something else like this.
At the first 10 seconds of running the engine, there´s no knocking.
And when i select the gear it´s quiet down, but when i drive the knocking is loud again.
What exactly is it doing knocking or a tapping? A cam bearing wont make noise however a lifter will make a tapping sound and will increase when you give it gas. A piston rod bearing will knock if it is wore enough and a piston wrist pin will knock but usually will go away when the engine warms up.
What your describing sounds to me like a rod bearing knock. Since you did'nt prime the engine before you started it you most likely spun a rod bearing.
Your description sounds like a valve lifter. It may go away as the engine warms up and oil flows better. Pull a valve cover and be sure there is sufficient flow.
Try pouring some oil down the push rod hole into the noisy lifter while the engine is running. It may just need a tiny bit to finish pumping up all the way.
Yes, i ask the seller of the car, it stands for about 2 years without oil. I´m going to "flush" the motor with the engine oil cleaner. Someone said that this would help. Or i have to drive with the car.
