351w running rough
Old May 13, 2011 | 11:04 AM
Kemicalburns's Avatar
Kemicalburns
Nope, it doesnt work that way. you may want to do a search on google.
Ford efi idle screw adjustment process. i know there is a bronco website that has just recently mentioned the process in detail but i cant post the link.
Old May 14, 2011 | 10:51 PM
zemus420's Avatar
zemus420
the high idle at startup could be your Throttle Position Sensor going out. Its located under the throttle body you need to take it off to replace it. All your symtoms point to that.
Old May 17, 2011 | 07:29 PM
fluffykins's Avatar
fluffykins
do you guys think i should buy an iac valve and tps or do you think i should by a code reader first? im on a tight budget so i dont want to be buying thins that i dont need.
Old May 18, 2011 | 09:56 AM
Kemicalburns
well the code reader is something you can use mutliple times and is an important troubleshooting tool. it will also help keep from throwing money at parts that dont need replaced.
Old May 18, 2011 | 03:14 PM
fluffykins's Avatar
fluffykins
will the code reader tell me exactly what part is bad?
Old May 30, 2011 | 06:51 PM
fluffykins's Avatar
fluffykins
i just got a code reader and code 33 and 133 came up. any idea what this means?
Old May 31, 2011 | 09:53 AM
Kemicalburns
the book should tell you what those codes are.
Old Jun 1, 2011 | 04:58 AM
Greyf100's Avatar
Greyf100
Ford Fuel Injection
If you're on a tight budget take the code reader back and read through that site. Get very familiar with it, LOTS of good info.
Old Jun 1, 2011 | 09:46 AM
Kemicalburns
those code readers are only 30 bucks and money well spent in my opinion. the book that comes with the reader has the codes in the back. the fordfuelinjection site is awesome and has plenty of info. good reference
Old Jun 2, 2011 | 03:02 PM
fluffykins's Avatar
fluffykins
ok i will cheak that site. i found that code reader for 8.00 at a parts house
80ford100
2004 - 2008 F150
Nov 17, 2015 09:31 AM
Toplait
Oct 10, 2015 12:13 AM
Dekoda Dale
18
Aug 16, 2015 10:30 AM
79_FORD_F-100
May 14, 2014 10:49 PM
Shwan_89HD
Mar 13, 2012 04:14 PM
