I was looking up different pistons available for the 300 and noticed quite a few sets with flattop pistons, but they usually say they fit from 65 - 76.
It said it was for the 240 and the 300.
So is there different things you can do? Get 70s era rods so the pins match? Dunno. Just think it'd be an easy way to score flat top pistons and get some compression. Who knows, maybe I'm way off base.
I have heard oversize 390 pistons are the way to go - but require re-ballancing - which would be a requirement anyway IMO. - I was just researching now - I'll check back.....
I have a 94 FI 4.9 that I'd like to raise compression and a mild RV cam. And change over to the ZF 5-spd tranny.
I have 360 pistons in mine, no rebalancing required, no pin bushing required. It really runs quite well. Just need to bore to a minimum of .050 over, I have mine at .080 with no issues, even in 98degree weather last summer.
