Dash Repair
Old Feb 7, 2017 | 02:26 PM
jacobthornton77's Avatar
jacobthornton77
Dash Repair
Help
I recently bought a fixer upper 1977 f150.
The some of my dash lights were broken off of the dash when I bought it.
Any ideas as to how to fix it would be great.
I was wondering if maybe there was a glue that was UV removable or something because I want to be able to replace the bulbs in the future.
Thanks
Also, if anyone has a four speed shift **** for a 1977 ford truck please contact me
Old Feb 7, 2017 | 02:59 PM
BigSexy78's Avatar
BigSexy78
I had the same problem. I got some sockets from some RV clearance lights and installed them. Wired them into the headlight switch and works great. Also upgraded to LED bulbs and WOW what a difference. I can see the gauges now!!
Old Feb 7, 2017 | 03:39 PM
jacobthornton77
Thanks thats a good idea
You wouldn't happen to have pictures of it would you?
Old Feb 7, 2017 | 03:50 PM
BigSexy78's Avatar
BigSexy78
Do not have pictures of them installed but here is what I used. They twist in like the originals. They were just a tad bigger but trimmed it with a razor knife to get them to fit. One wire to ground and the other wire to the light switch. You will need 2 for your dash lites.
Old Feb 7, 2017 | 03:59 PM
jacobthornton77
Great Thanks!
I will try that.
If it works I will make a post explaining how to do it and credit you if thats okay?
Old Feb 7, 2017 | 04:12 PM
BigSexy78's Avatar
BigSexy78
Thats fine.
Old Feb 7, 2017 | 04:13 PM
ZarK-eh's Avatar
ZarK-eh
That housing looks kinda cracked. Is the housing the kind that turns to dust? I had to junkyard one from an econoline myself.
If you can poke a hole in it with your finger, it's the crap kind that turns to dust.
Old Feb 8, 2017 | 05:09 PM
jacobthornton77
That is the problem the holes have broken away and larger hole is left.
It is not the kind that turns to dust as far as I know.
Old Feb 8, 2017 | 10:40 PM
PapaBearYuma's Avatar
PapaBearYuma
Looks to me like the kind that turns to dust. I've had two of them do it. Anyway, to get a little more life out of mine, before I gave up on them, I superglued the bulb sockets in place. Of course you never get them out again, but the bulbs live practically forever
Old Feb 10, 2017 | 02:42 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
It IS the kind!
1975/79 F100/350; 1975/80 Econoline; 1978/79 Bronco:
The instrument cluster backs were made of a composition material that can TURN TO DUST before your very eyes!
1981: Ford came out with hard plastic cluster backs for Econolines. These were also the "service part replacements" for the POS cluster backs.
There are two different types: 1981/86 Econoline with Oil/Amp WARNING LAMPS or 1981/91 Econoline with Oil/Amp GAUGES.
Med1455
Apr 1, 2016 09:00 PM
vwfreak
Nov 6, 2013 06:21 PM
Ponyboychris
44
Feb 13, 2011 10:12 AM
bdrummonds
16
Feb 7, 2009 11:01 PM
