Sponsored by: Real Truck
Upgraded rear diff cover
Old Feb 15, 2011 | 11:47 AM
jetact's Avatar
jetact
Saw all of you that bought the upgraded rear diff cover with the cooling fins. Had to get it polished a bit to add a little to it.
Old Feb 15, 2011 | 12:13 PM
Gage2502's Avatar
Gage2502
Nice job, your truck looks really good.
~Gage~
Old Feb 15, 2011 | 12:37 PM
BigPigDaddy's Avatar
BigPigDaddy
Did you polish it yourself or where did you get it done and how much $?
Old Feb 15, 2011 | 12:54 PM
jetact's Avatar
jetact
Thanks Gage. @BigPigDaddy, I had a guy polish it for me. He does blowers and things like that. Just an independent guy. He ground off all of the numbers on the outside ring and smoothed it out. He does great work. It would go on a show truck. My truck is a DD so it didnt need to be this good but thats how this guy does everything. I am into it $150.00
Old Feb 15, 2011 | 03:45 PM
Furian's Avatar
Furian
You Keep What You Kill
Looks like chrome!
Old Feb 15, 2011 | 05:57 PM
bpounds's Avatar
bpounds
Are you going to coat it with clear lacquer?
Old Feb 15, 2011 | 07:34 PM
jetact's Avatar
jetact
You know bpounds I asked the guy who did the polishing if I should and he said no. I dont know as everything I have ever had polished was easily accessable and cleanable. This will be some work to keep clean.
Old Feb 15, 2011 | 08:43 PM
_Rick_'s Avatar
_Rick_
jetact,
That's damn shiny. I poked through your gallery, but couldn't find any photos of it installed?
I went for exterior color match myself. A few coats of paint and a few coats of clear sealer and it seems to be holding pretty good so far. Around 7 months now since install.
Rick...
[/IMG]
Old Feb 15, 2011 | 11:39 PM
jetact's Avatar
jetact
Rick, I like your color match. No I have not installed it yet as I just got it back today.
Old Feb 16, 2011 | 01:35 AM
_Rick_'s Avatar
_Rick_
Well,,, you did post the photo of the freshly polished diff cover at 09:47 AM so I figured you would have had it installed by dinner time including a few hours of allowing the new seal to cure and filled up with full synthetic fluid.
I'll be looking forward to seeing it installed.
I don't know if you actually need the input or not, but just in case it might help you here's a few links to some very helpful information reguarding diff covers and fluid changes:
My rear differential service - with pics (courtesy of bpounds)
and or
Fluid Change on the Sterling 10.5 Rear Differential (courtesy of Guzzle)
and the front if you get ambitious
Fluid Change on the Dana 60 Front Differential (also-courtesy of Guzzle)
There are other helpfull threads here on FTE to help with this project, but i think between the above two contributors you will be fine.
Rick...
Old Feb 16, 2011 | 09:42 AM
jetact's Avatar
jetact
@Rick. LOL !!! Yes I was thinking that I should have torn it down today and did it but we are expecting some snow today and end of the week. I think I will look at it for a bit and wait for the weather to get a bit nicer. Thanks for the links to the info. I had see a few of those and was going to look them back up for bolt size and oil type. I have the limited slip and have read on some threads that people have and have not had to add the limited slip juice. Thanks again for the help.
Old Feb 16, 2011 | 04:52 PM
_Rick_'s Avatar
_Rick_
If you go with full synthetic gear oil you'll be ok without the limited slip additive (products like Royal Purple are pre-loaded with limited slip modifier). The full synthetic oils are more expensive, but I'm convinced you're better off with it (only my opinion of course). I'm sure you'll get many suggestions re: dino vs synthetic and brand vs brand, but the bottom line is,,, you'll be ok which ever way you go as long as you follow instruction properly for either.
I like the Royal Purple products myself. I've converted my truck 100% to Royal Purple and have had no issue at all with my choice. But you do have several choices so just do a little research and pick a product you're comfortable with. I'm sure you'll be ok with any recommended name brand product you find here at FTE.
Rick...
Old Feb 16, 2011 | 05:06 PM
jetact's Avatar
jetact
Rick...
Thanks Rick. Yes I will go Synthetic. I pulled my motor this last fall and did abunch of work to it and switched to Mobil 1 turbo diesel Syn. I think it is worth the extra money ($80 for just the oil) to have the syn. I will look for the royal purple with the limited slip modifier in it.
jofes
Nov 5, 2016 09:26 PM
hharris8
1978 - 1996 Big Bronco
Sep 5, 2016 09:49 AM
dagomachining
Jun 22, 2014 09:36 AM
allis327
15
Sep 13, 2009 08:38 AM
Peter Richards
Jun 16, 2007 09:50 PM
