Yes, you will need longer bolts as the 08 cover is noticeably thicker than the stocker. I don't remember what size is needed as when I picked my cover up from the stealership they also supplied me the new bolts (for an additional charge obviously). Hopefully someone else can help enlighten you on the exact size. If I had to guess I would say 1.25".
Yep -- you're covered. It was hard to find them in SS at Lowes/HD, so I went with 1 1/2 and bought some extra flat washers for spacers. Only a couple needed them. Most tightened up fine with just a single flat & lock washer. What kind of fluid are you using? I went with Royal Purple syn 75W-140 with the friction modifier in it already. It worked out perfectly. Here's what mine looks like:
