cooling system additive(test strips)
Old Feb 14, 2011 | 03:25 PM
Calli's Avatar
Calli
Does anyone on the forum sell Motorcraft Cooling System Additive along with the test strips? Trying to change back from the Final Charge ELC in my early '99. Dealer has one bottle, no strips. Thank you
Old Feb 14, 2011 | 03:55 PM
Stewart_H's Avatar
Stewart_H
I think Clay does. Check his website out.
Stewart
EDIT: http://www.riffraffdiesel.com/mm5/me...Code=F731-MISC
Old Feb 14, 2011 | 04:28 PM
Calli's Avatar
Calli
Thanks Stewart, Site has strips, can't find additive??? Anyone home, Please?
Old Feb 14, 2011 | 04:39 PM
429 f-100's Avatar
429 f-100
napa has the additive (napa kool) THE FORD DEALERS NOW HAVE VC-9 ONLY I BELIEVE . NOT THE FW15
Old Feb 14, 2011 | 05:58 PM
Shake-N-Bake's Avatar
Shake-N-Bake
I get mine from NAPA. You can also buy the additive in pint, quart or gallon as well.
Old Feb 14, 2011 | 06:10 PM
Stewart_H's Avatar
Stewart_H
Wes, VC-9 is not a Supplemental Coolant Additive (SCA), it's an iron remover used to flush the engine's coolant system.
VC-9: Diesel Engine Coolant System Flush
You see it mainly used by the 6.0L guys, especially if they've had an oil cooler failure.
If they have suffered an oil cooler failure, then after flushing with VC-9, they'll flush with Simple Green or Cascade.
Stewart
Old Feb 14, 2011 | 07:17 PM
BadDogKuzz's Avatar
BadDogKuzz
I also have a e99 and I hope that you aren't switching because of problems with seals if so it is too late. Hopefully you are doing it because you don't want seal failure. I have never charged from old school green and have problems with keeping my SCA's correct using the NAPA brand. Use the VC-8 it is also on sale at Motorcraft diesel engine coolant system additive And as far as the VC-9 goes it wouldn't be a bad idea to flush with it before going back. I was told that VC-9 is what I was told to do by the dealership when flushing ( iron and tap water throws off the ph)and start fresh with the VC-8 because the NAPA brand is a DC-2 and VC-8 is a DC-4 or at least I think that was what it was. I don't remember. Actually there was a very good write about it here(FTF) a few weeks ago. Stewart didn't you do a write up on that one ? But there was some GREAT info on that tread. I'll see if I can't find it.
Old Feb 14, 2011 | 07:23 PM
BadDogKuzz's Avatar
BadDogKuzz
This should be helpful. https://www.ford-trucks.com/forums/1...st-strips.html
Old Feb 14, 2011 | 07:53 PM
Stewart_H's Avatar
Stewart_H
Good memory bro. I post so much coolant info on FTE, I actually forgot about that post.
Originally Posted by Stewart_H
A lot of your coolant questions can be answered in this thread: https://www.ford-trucks.com/forums/960812-goochs-radiator-engine-backflush-procedure-and-coolant-information.html#post8935201
That's a thread I put together from all the information I could find posted by Gooch, as well as through PM's with him. Gooch is a coolant expert and posts on various diesel forums on the 'net.
In regards to your SCA question, DCA-4 contains phosphates, so it's even more important you do not use tap water to refill your engine.
Tap water is hard water. Some places have very hard water. The problem is, hard water contains calcium and magnesium (minerals found in tap water), which reacts with the phosphate inhibitors in DCA-4 to form calcium or magnesium phosphate, which typically leads to scale formation on hot engine surfaces.
This could lead to loss of heat transfer or corrosion under the scale
So make sure you use distilled water to flush out the tap water you use to backflush your engine block.
Stewart
Here I go, quoting myself...isn't that like talking to yourself? Am I still ok if I don't answer myself?
Stewart
Old Feb 14, 2011 | 09:10 PM
Calli's Avatar
Calli
Bad Dog,
Thanks for the link. Have ordered coolant additive. Try somewhere else for strips. No problem yet. Just trying to avoid. Thanks
Old Feb 14, 2011 | 10:26 PM
BadDogKuzz's Avatar
BadDogKuzz
HaHa Stewart Yea it is like talking to yourself but it was all for a good cause. Thanks I needed that to remember about the differents in Dc-2 and DC-4. I have yet to try adding the VC-8 cause the NAPA brand only seems to keep my levels in check for about a month at a time. Actually I need to start all over with a flush and all NEW.
CAlli, I use Baldwin test strips and get them at a semi truck parts store. But make sure before you buy test strips to check the exp. date. Yes they do go bad. You want fresh ONES !!
Old Feb 15, 2011 | 06:25 AM
429 f-100's Avatar
429 f-100
[quote=Stewart_H;9968195]Wes, VC-9 is not a Supplemental Coolant Additive (SCA), it's an iron remover used to flush the engine's coolant system.
thanks stewart i called my ford dealer who i know realy well i buy alot of parts from him as a body shop . i asked him how much fw15 was he told me he did not have it . i said what does your service dept use . silence than " the generic stuff we got in the 55 drum. the only thing we got is the vc-9." i called my orielly parts house guy do you guys have coolant additive (sca) ? no we dont . he called me back ten minuites later hey ------- ford down the street has the vc-9 stuff you want me to get it for you?.. it amazes me that no one understands this . but i was guilty to as i only used green original style added fw15 pobbibly the first two changes in my truck. than just straight antifreeze last couple with tap water to boot. thought i was doing good switching to elc but now gonna flush and start agian. i wonder how many water pumps they sold later because of there practice?
Old Feb 15, 2011 | 06:26 AM
RNH Performance's Avatar
RNH Performance
I just bought some fresh strips email me your address and ill send you a couple if you dont want to spend the 25 for the kit.
Old Feb 15, 2011 | 06:30 AM
RNH Performance
Rnhperformance1@gmail.com
Sorry mobile ap wont let me edit my previous post.
Old Feb 15, 2011 | 07:37 AM
Calli's Avatar
Calli
RNH. Very much appreciate the offer but I ordered the strips from RiffRaff this am. Ordered the additive from Motorcraft Diesel last night. Just seemed like I could find both in one spot. Guess that would be too easy.
Thanks again, I owe you one.
