Harmonic Balancer install
Old Feb 14, 2011 | 01:30 PM
2002fx4122's Avatar
2002fx4122
last month i installed my harmonic balancer on my 466 (460 bored .030) and when i was putting the heads on this past weekend I noticed the balancer isn't flush with the the end of the crankshaft. I'm not sure if it's suppose to be? I rented the installer from a local parts store and i thought i had it all the way on.
Old Feb 14, 2011 | 02:28 PM
mark a.'s Avatar
mark a.
Not sure what you mean by flush with the end of the crank ? If your belts are in line with the cranks pulley then I'd say it's ok.
Old Feb 14, 2011 | 04:27 PM
2002fx4122's Avatar
2002fx4122
theres about an 1/8 inch gap where the balancer could slide on that much more. It seems like it needs to be flat so the large washer and bolt that holds it on can be on there flat
but I haven't got the pulleys on yet, i finally got the head put on last weekend
Old Feb 14, 2011 | 07:18 PM
mark a.'s Avatar
mark a.
Are you saying there is a gap between the dampener and spacer ? How do the belts look ?
Old Feb 14, 2011 | 08:15 PM
Don Senkow's Avatar
Don Senkow
It's not supposed to be flush. You're probably fine...... Don
Old Feb 14, 2011 | 08:38 PM
2002fx4122's Avatar
2002fx4122
i dont have the pulleys or belts on yet
hopefully i can get over to the shop on wedensday and get a picture. it seems like the spacer is seated into the timing seal but theres the small gap between the end of the crankshaft and the face of the balancer
Trstrugar
13
Feb 18, 2017 08:15 AM
jsfrenchfl
May 26, 2016 12:01 PM
ROKRAWL
1966 - 1977 Early Broncos
May 27, 2013 07:10 PM
crazer42
Dec 15, 2010 04:59 PM
CJ7
Nov 25, 2003 05:42 PM
