302 timing mark on harmonic balancer
Old Nov 25, 2003 | 02:31 PM
CJ7's Avatar
CJ7
Hi Folks. We are still trying to get my Grandson's 89 FSB to crank. What do the timing marks on the harmonic balancer look like? Some PO has put a white mark on the harmonic balancer where the pointer is at when the #1 cylinder is TDC. I was out playing in the mud this past weekend and met a Ford mechanic. He told me something about the wide cut in the harmonic balancer being for distributor timing. Is this true, or is there another mark on the harmonic balancer for timing?
Old Nov 25, 2003 | 03:18 PM
monza1's Avatar
monza1
My '92 has the degrees marked on the balancer. clean the edge of the balancer and you should be able to read them.
Old Nov 25, 2003 | 03:43 PM
jelloslug's Avatar
jelloslug
I can tell you from my recent trials getting the timing set on my '88 that the wide cut is not the timing mark. Look closely at the balancer and you will find degree marks from 10° after TDC to 30° before TDC. I had to clean the rust off of mine with steel wool to find them. Hop this helps some.
Old Nov 25, 2003 | 05:42 PM
CJ7's Avatar
CJ7
Thanks monza1 and jelloslug for taking the time to help. I found the marks.
gary's1950F1
Nov 21, 2016 11:11 PM
ragens 87
Jul 4, 2016 05:56 AM
jsfrenchfl
May 26, 2016 12:01 PM
olderford76
New Member Introductions
Sep 14, 2015 11:21 AM
84respass
Oct 5, 2010 10:09 PM
