1964 Dash Controls
Old Feb 18, 2011 | 06:57 PM
  #31
gangstakr's Avatar
gangstakr
Originally Posted by CropDusterMan
Yer right Robert...just when we're waiting for the yards to open.
Outside the vehicle.......... I'm done
Old Feb 20, 2011 | 03:49 PM
  #32
ocbp1981's Avatar
ocbp1981
Lighter
My lighter did not work but was the original to the truck with bezel and black *** with white insert. I bought the replacement lighter housing from Carpenter and was able to attach the original *** and bezel to it although it took a lot of work to disengage it from the original one since it is as number dummy said was swagged on (which I have no idea what that is) but it was really stuck good. Now it works great and looks original.
Dammit. Now I need to go on the hunt for a proper lighter for my truck.
Thanks Bill.
Old Feb 20, 2011 | 03:57 PM
  #33
ocbp1981's Avatar
ocbp1981
Ashtray Chrome Molding
Hey since we are talking about the cigar lighter thought this was a good fit. Does anyone have the ashtray chrome molding for a standard cab dash 1966 f250. It is a little piece of chrome that goes over the top of the ashtray edge. Thanks
Old Feb 21, 2011 | 12:26 AM
  #34
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There is no "little piece of chrome" that goes on the ash tray edge on any Standard Cabs, Custom Cabs or Rangers.
Someone fabbed it up, possibly cutting a section from a chrome door edge guard.
The only dash mouldings in this area these trucks had were anodized aluminum and were used with tu-tone paint (to separate the upper dash color from the lower dash color) or used to cover the leading edge of the padded dash.
There is a long moulding (C4TZ-8104332-A) on the passenger side, a short moulding (C4TZ-8104333-A) on the drivers side.
Old Feb 21, 2011 | 12:29 AM
  #35
ocbp1981's Avatar
ocbp1981
Ashtray trim
Bill what is this part then?
Here is a link to one that included the dash strip which I have. 1961 1966 FORD TRUCK DASH TRIM MOLDING W/CLIPS NICE!!! - eBay (item 160545233834 end time Feb-19-11 09:19:35 PST)
Old Feb 21, 2011 | 12:42 AM
  #36
NumberDummy
Bill what are these parts then?
These are the same mouldings I mentioned in post #34. These were used on 1964/66 F100/1100's, 1964/69 N/NT500/1000's and 1967/69 F800/1000's...as all these trucks used the same basic dash.
Not original for 1961/63's (as the ebay seller claims). If found on these earlier trucks, they were retrofitted.
1) C4TZ-8104332-A .. Instrument Panel Finish Moulding-Right.
1) C4TZ-8104333-A .. Instrument Panel Finish Moulding-Left.
8) 379852-S3 .. Clip, Instrument Panel Finish Moulding.
The long right side moulding (uses 6 clips to attach it) fits just above the ashtray and spans the entire right side of the dash...beginning just past the instrument cluster
The short left side moulding (uses 2 clips to attach it) fits above the ignition switch from the cluster towards the end of the left side of the dash..
btw: When you said: "Over the top of the ash tray edge" I thought you meant on the ash tray edge itself, not above it.
Old Feb 21, 2011 | 12:46 AM
  #37
ocbp1981's Avatar
ocbp1981
Molding
Bill, Thanks, I thought the small one was for the ashtray since I saw a truck with one on the ashtray.
Old Feb 21, 2011 | 01:03 AM
  #38
The Masked Rider's Avatar
The Masked Rider
Bill, are the two parts and the clips available? The original owner had removed the long piece to the right side for some reason ??? and the one on the left looks like crap. I would like to get a replacement.
Thank you, Fritz
Old Feb 21, 2011 | 01:12 AM
  #39
ocbp1981's Avatar
ocbp1981
1960’s Ford truck cigarette lighter **** & element, NOS
1960
Bill how do you search for parts at:
GRIESEL MOTOR CO.
ED BENNETT FORD PARTS
That's an autoparts store replacement lighter **** and element, it's not from any FoMoCo vehicle. If it was from a Falcon, it would have a black **** w/a chrome center and a bezel marked LIGHTER.
1961/66 F100/1100:
The bezel marked LIGHTER is part of the element (C1TZ15054A), and it was swagged on, so it cannot be removed. I could not find anyone that reproduces it.
The ****, as original, was only sold with the element (C1TZ15052A). Carpenter's part number (C1TZ15052) for the reproduced **** is phony...because it's only the ****.
The correct 1961/66 element is hard to find NOS as Ford replaced it decades ago with first the '67/72, then the '73/79 types, which are different styles and do not say LIGHTER.
C1TZ15054A .. Lighter Element w/Bezel =
NOS PARTS SOURCE in Lenexa KS has 1 = 913-220-5746.
WEST BRANCH FORD in West Branch IA has 1 = 319-643-3673.
WESLEY OBSOLETE PARTS in Liberty KY has 3 = 606-787-5293.
GREEN SALES CO. in Cincinnati OH has 4 = 800-543-4959.
C1TZ15052A .. Lighter **** & Element Assy =
WESLEY OBSOLETE PARTS has 1.
GRIESEL MOTOR CO. in Okarche OK has 1 = 405-263-7242.
ED BENNETT FORD PARTS in Lebanon PA has 1 = 717-272-8762.
The lighter fuse was not integral with the harness...or the socket (though it might appear as such). It was sold by itself.
FEW14429A .. Lighter Fuse / Obsolete.
This fuse is barrel shaped, has one female, one male end. Female end threads onto the lighter sockets male end, then the wire end pushes onto the fuses male end.
The original factory installed fuse has a hole in it...using a paper clip (or similar), the fuse can be reset.
GREEN SALES CO. has 8.
KLIMESH MOTOR SALES in Calmar IA has 8 = 563-562-3241.
TISON MOTOR CO. in Estill SC has 10 = 803-625-2551.
MILLER OBSOLETE PARTS in Vestal NY has 11 = 607-722-5371.
SALEM MOTORS in Crookston MN has 11 = 218-281-1338.
Note: The 4 way emergency flashers were an option, so very few trucks have it...and there were...at least FIVE different types for 1961/66's.
Finding the correct 4 way flasher dealer installed kit or the individual parts may be a challenge.
Old Feb 21, 2011 | 01:14 AM
  #40
NumberDummy
Thank you, Fritz
Obsolete No Ford Dealer or obsolete parts vendor has the mouldings. MANDERBACH FORD in Temple PA (610-929-3683) has ONE moulding clip...and that's it..
I looked in DC's and Carolina Classics truck repro parts catalogs, didn't see any listing for these parts...possibly someone else has them.
Old Feb 21, 2011 | 01:26 AM
  #41
NumberDummy
Bill how do you search for parts at: GRIESEL MOTOR CO. ED BENNETT FORD PARTS
In-house FoMoCo Dealer Parts Locator System, only available to authorized dealers (*)...as confidential info (MSRP & dealer net cost prices for EVERY available part is listed, as is other jazz).
* I know that obsolete parts vendor Green Sales Co. has access (there may be others-Dennis Carpenter, for example), cuz they know someone at a dealership that has the link to the site and a valid password to access it.
Old Feb 21, 2011 | 03:04 AM
  #42
The Masked Rider
Thanks Bill. Maybe someone on the board will know where I can get one. I do have many of the options on the truck that I just took for granted. When i hear that many of the 65's out there don't have them, I feel very lucky. BUT, than there are the little things that are missing that have to be scrounged. Do you have a customer list that you keep in case you find what they need??? If so, put me on the list. I may start a list of my needs for you. I think I'll start with a 'long vacation, and $100,000 to play with.' What shelf might that be on. ;o) HAAAAAAAAAAAAAaaa
Fritz
Old Feb 21, 2011 | 01:38 PM
  #43
sammycooks's Avatar
sammycooks
lighter element and bezel on eBay
here's another, and very affordable...
Auction says 73, but looks correct, and putting a new 60's **** on it should have you set...
1973 Ford Truck Lighter Element & Bezel D3TZ15054B NOS - eBay (item 130485269050 end time Mar-12-11 20:34:03 PST)
Cheers
78 & 87 Super Cab
19
Mar 31, 2026 09:52 PM
72CC428
Jun 2, 2016 03:25 PM
nagetech
Aug 20, 2015 10:17 PM
Shadowrider123
Sep 8, 2014 04:56 PM
1964FORDTUF
Mar 9, 2014 04:59 AM
