2005 Explorer Cigarette Lighter
Old Aug 20, 2015 | 09:52 AM
nagetech's Avatar
nagetech
Howdy!
I am helping a friend out. She has a 2005 Explorer XLT. Both of her cigarette lighter / power accessory ports are not functional.
I thought it would be an easy fix. I cracked out the manual, looked up the fuses and found fuse 24 (under dash) for the cigar lighter. I replaced the fuse, but no dice
I looked inside both ports, and I don't see anything in there that could be tripping it / grounding it.
Reading over the rest of the manual, I didn't see anything else that would suggest there was another fuse for it, unless I am missing something.
Could anyone be of assistance?
Old Aug 20, 2015 | 04:39 PM
AzPete's Avatar
AzPete
Mine were unplugged in my 07 when I bought it. There should be plugs either on the end or within a couple if inches of the socket.
Old Aug 20, 2015 | 10:17 PM
shorod's Avatar
shorod
Do you have a way to confirm whether or not the ports actually have power? Maybe the fuse in whatever she is trying to plug in is blown. Those often have a fuse either in the side of the plug or beneath the tip.
If you are able to confirm the plug does not have power, it appears from the wiring diagrams you should be looking at fuses F7 and F9 (both 20A) in the Battery Junction Box. Fuse F24 is just for the front cigar lighter.
-Rod
Whitey Ford
20
Dec 14, 2019 11:41 AM
fordtruck630
Nov 19, 2014 03:52 PM
quietman
Mar 21, 2013 09:06 PM
quietman
Nov 19, 2008 11:51 PM
kevchoate
Jan 31, 2005 05:03 PM
