Hard starting
Old Feb 12, 2011 | 03:37 PM
tootall5764's Avatar
tootall5764
Hard starting
I have a 93 F-250 that cranks very slow but usually starts fairly easy when cold. After it is warmed up and shut off it will have to be cranked for 15-20 seconds sometimes longer to get it to start. I have new batteries a new high torque starter installed but it still cranks really slow. Any help would be appreciated.
Old Feb 12, 2011 | 05:21 PM
wreckinball's Avatar
wreckinball
if the cables are stock or old and cracked, then nothing will help. Check the cables and grounds. new batts and a new starter should wake that thing up big time. I never knew how slow mine cranked till i replaced the starter. the extended cranking could be due to the slow cranking or air intrusion but check all the large battery cables and connections, then check them on the starter and frame mounts. Best luck!
Old Feb 12, 2011 | 05:35 PM
Phy's Avatar
Phy
What Wreck said! I'd be looking really hard at the cables & connections.
Diesels need to spin fast to fire...
Old Feb 12, 2011 | 06:22 PM
tootall5764
Thanks much, the cables are original and have had the factory end replaced so you guys are probably right. I was hoping that wouldnt be the problem since the pos cable is so expensive. I have been reading some other threads and I checked my return lines and it appears a few are leaking in between the injectors so I will change those and hope that is the problem. Thanks again for the advice.
Old Feb 12, 2011 | 06:30 PM
wreckinball
just buy the cable by the foot and make your own.
Old Feb 12, 2011 | 10:12 PM
85grey's Avatar
85grey
That stuff will all help your problem. Another thing that I do is take my starter off every fall. take it apart and clean it and reassemble and reinstall
Old Feb 12, 2011 | 10:29 PM
wreckinball
seems kind of overkill for a relatively inexpensive item, especially with boschs lifetime warranty. Either way, it isnt the starter causing slow cranks of he just put it in. Good tip though, just not for me, i hate that top bolt!!
Old Feb 13, 2011 | 07:18 PM
tootall5764
I appreciate all the advice. It appears that you guys were right. Thanks for all the help.
rjack
Jun 3, 2013 07:15 AM
79fordf250pickup
Feb 8, 2012 11:28 PM
DubDub
1983 - 2012 Ranger & B-Series
19
Jan 28, 2008 04:36 PM
kwaskow
Feb 3, 2005 07:52 AM
cadiecast
Aerostar
Jun 26, 2002 07:49 AM
