Aerostar Ford Aerostar
1995 3.0 engine problem
Old Jun 23, 2002 | 11:17 PM
cadiecast's Avatar
cadiecast
Post 1995 3.0 engine problem
Engine started to crank over at a normal start speed, then I felt and heard a quick thump that sounded like something had broke internally. The engine now cranks over very slow as if the battery was going dead. The battery and starter are both fairly new. The engine cranks to slow to even get an accurate compression test. I have had a few amateur mechanics listen to it crank over, and one has said that it sounds like there is no compression. I also have spark. What type of problems would cause the engine to crank slow and not fire? Any suggestions or ideas would be greatly appreciated.
Thanks,
Chuck
Old Jun 25, 2002 | 06:17 AM
dougas's Avatar
dougas
this is just a guess when i change engines.my engine it did the same thing it turned over reel slow the problem was it was the ground wire from engine to frame you might want to check it just in case or you could check your starter could be weak
Old Jun 25, 2002 | 08:34 AM
dougas's Avatar
dougas
[updated:LAST EDITED ON 25-Jun-02 AT 09:36 AM (EST)]In my earlier post I told you to check the ground wire from frame to engine. Clean it with sandpaper. Check your battery cables, clean them. You could also have transmission problems. Or a bad crankshaft position sensor. Timing chain will give the same symptoms. Weak starter. Make sure your battery is good. Might be the solenoid. Hope it's not the head gaskets. Please reply on what you have checked so far.
Old Jun 26, 2002 | 12:07 AM
scott9050's Avatar
scott9050
I second checking the battery. Mine did the exact same thing tonight and the battery was tested and was found to be bad.
Old Jun 26, 2002 | 07:49 AM
rjcline's Avatar
rjcline
93f150guy
1997 - 2003 F150
Oct 31, 2010 10:21 PM
O2BNMUDD
Oct 23, 2008 06:34 PM
DubDub
1983 - 2012 Ranger & B-Series
19
Jan 28, 2008 04:36 PM
JMakin
Nov 12, 2004 01:25 PM
89f350
Jul 18, 2004 10:39 AM
