old engine high idle
Old Feb 11, 2011 | 09:05 PM
chessman21's Avatar
chessman21
1967 330 (could be 331)v8 commercial engine has very high idle.. I unplugged vacume line from distributer and idle slows down to about normal, any ideas?
Old Feb 12, 2011 | 06:25 AM
Talltruck's Avatar
Talltruck
Two things -- the advance line shouldn't have vaccum on it at idle; it's supposed to be a "ported" line that only has vacuum at a higher rpm. Either the idle is set too high opening the port and allowing vacuum to pass thru or it's connected to a non-ported outlet. Bottom line, if it has full time vacuum it will advance the timing at idle and up the idle speed.
Second, a high idle is usually connected to vacuum leaks somewhere, if the advance problem doesn't fix everything then start looking for a vacuum leak.
Old Feb 12, 2011 | 08:32 AM
CropDusterMan's Avatar
CropDusterMan
I had a similar issue recently...had a vacuum leak on the transmission vacuum line that goes to the intake...I fiddled and faffed about for quite a while before finding it...hose was worn and rounded out at the trans. Once I replaced it, it timed in really quick.
jetfiremuck
Aerostar
Sep 5, 2014 05:52 PM
nosebreaker
Mar 29, 2011 08:09 PM
Rudiak
6.4L Power Stroke Diesel
Feb 13, 2011 07:46 AM
san antonio
Feb 10, 2011 10:26 AM
akorcovelos
Nov 3, 2010 10:30 AM
