Whining Transmission
Old Feb 9, 2011 | 06:13 PM
Craig5_12's Avatar
Craig5_12
My '69 F100 just developed a whine from somewhere around the tranny. The closest sound that it resembles is the whine you get from trying to turn farther than the power steering allows. I don't know what tranny is in it, but it's a 3 speed automatic hooked up to a 289. It makes the most noise in Park or Neutral and when I put it in Drive I can hear it up to about 10mph. When I accelerate in any gear I can hear the whine increase with the engine speed up to a certain point. Fluid level is just fine and it makes the noise Hot or Cold.
Any ideas?
craig
Old Feb 11, 2011 | 09:59 AM
GreenDinosaur's Avatar
GreenDinosaur
Last time I heard an auto tranny make that kind of noise it was ready for a rebuild. Have you changed the fluid and filter?
Old Feb 11, 2011 | 10:04 AM
jeremy sanders's Avatar
jeremy sanders
my 68 whines 2 sounds like a belt sqeal tho an i replaced front pump an the bushin an it stopd mines a c6 they got funny lookinpans
Old Feb 11, 2011 | 07:32 PM
Craig5_12's Avatar
Craig5_12
Boy do I feel dumb...turns out it wasn't the tranny at all. I started hunting around with a dowel to pinpoint the sound and found that it's coming from the alternator. I took the belt off and whaddya know, no more whining. Spinning the rotor by hand I notice that it's not straight, so it's probably a bearing or something in there. Are alternators repairable...or rather...is it worth it to try and repair...or should I just buy a new one when this one quits?
The good news (besides not having to work on the tranny) is that I discovered the tranny I have is a C6. Which means when I build up my old 390 and take out the current 289, I shouldn't have to worry about blowing up the transmission! ...it'll probably be the rearend instead....
Old Feb 12, 2011 | 11:25 AM
zenmaster's Avatar
zenmaster
Craig5_12,
You can buy an alternator rebuild kit at any auto parts store. About $25.00 up here in Canada... probably less in the US.
Cheers,
John
F150MUTT
2015 - 2020 F150
Aug 12, 2017 02:29 PM
TGD-IA
Oct 26, 2016 03:23 PM
srobison
Jan 15, 2013 07:08 AM
5.4L to Freedom
Dec 16, 2010 05:51 PM
cb88
Bronco II
Jun 25, 2005 07:22 PM
