Aerostar Ford Aerostar
High idle
Old Aug 29, 2014 | 08:55 PM
jetfiremuck's Avatar
jetfiremuck
High idle
Van started this last week. After shut down then restart engine revs to 1500 or so for about 5 secs then slowly drops to idle. The wait is a pain as the idle is too high to put in gear. Cleaned air bypass, checked throtyle stop etc all ok. Any other ideas
Old Aug 29, 2014 | 11:00 PM
96_4wdr's Avatar
96_4wdr
"Cleaning" the IAC does not always work, worn out internal parts driven by a high frequency PWM signal from the PCM.
replace, they wear out internally.
Clean the throttle body plate area with carb cleaner, wipe with a clean rag soaked in carb cleaner as far as you can reach in. They build up with dust and hair ***** that the AF does not catch. Jams the plate from closure until vacuum builds up behind plate.
Check for codes, not all pop at CEL.
Old Aug 30, 2014 | 10:26 PM
xlt4wd90's Avatar
xlt4wd90
My "favorite" cause is a loose vacuum line; check to make sure all the lines and plugs on the tree at the rear of the intake manifold, driver's side, are in place.
You can test the air bypass valve by unplugging it while it's in this high idle mode and see if it drops. If so, the valve is working, but the EEC is opening it up for some reason. Then it's a sensor problem; there are sensors for temperature, oxygen, and throttle position.
Air flowing through the MAF sensor comes directly from the filter, so should remain relatively clean, unless the paper filter element is disintegrating. The throttle plate builds up oily residue from the PCV, which enters the air tube behind the MAF sensor. Later models also have EGR, which puts more crud into the intake tract, behind the throttle plate. Sometimes you have to use a stiff wire brush and carb cleaner to loosen that stuff up.
Old Sep 5, 2014 | 05:52 PM
jetfiremuck
Follow up. I ordered the motorcraft bypass. I guess after 426k miles it needed replacing. Installed new one and all problems high idle, idle surge have gone. Thanks for the pointers.
troubled1
15
Aug 24, 2016 04:12 PM
tom82
1997 - 2003 F150
Oct 12, 2011 01:11 AM
fordtruckinsml
16
Apr 12, 2004 07:28 PM
baurley
Aug 31, 2000 01:34 PM
island
Jul 4, 1999 04:42 PM
