6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Rear power window not working.
Old 02-17-2011, 03:04 PM
FSTBLL42's Avatar
FSTBLL42
FSTBLL42 is offline
FSTBLL42 is starting off with a positive reputation.
2008 KR Crew Cab SWR 4x4 6.4.
Hey guys not sure if anyone has had this problem or not. I took he backing off from the back of the cab and it looks like the wire has gotten bound up in the spool. So now nothing happens when i push the open button on the dash. I put the seat backs down and watched as the wire barely moved. My questions is how do you get it apart? I has rivots not bolts on the spool. There are three bolts that are holding this item up on the back of the cab but that is only to take the whole thing down not fix the spool. Thank you for your help in advance. If i need a new steup does anyone know where i can get one.
Travis
Old 02-21-2011, 01:06 PM
fireman28's Avatar
fireman28
fireman28 is offline
fireman28 is starting off with a positive reputation.
I know when mine stopped working the cable had popped out of the holder on one end. By holder I am talking about the blaqck molded plasic at the bottom of the glass near the corner. It had broken through the plastic. Ford did a design change on it in later models. The rear window and cable assembly are one piece design. I had to get a whole new window. $800 plus from Ford installed. My extended warranty covered it though.
Amilledge8
02-25-2012 05:47 PM
strokin'_tatsch
16
07-16-2010 03:39 PM
351slug
Offroad & 4x4
17
11-12-2007 06:20 AM
05f250fx4
28
12-26-2006 05:30 PM
KRMFiero
Offroad & 4x4
04-17-2002 10:47 AM
Quick Reply: Rear power window not working.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
