Wiring Diagram for rear window defrost circuit 2002-2005 EATC
Anybody have (or have access to) a wiring diagram that will show me how the rear window defroster circuit works in my Excursion. I have the EATC, which may or may not be related... not sure. So the digram would probably need top be from 2002-up.
Obviously I ask because mine is not working (and neither are the mirror heaters since they are activated by the same switch - I think???). I've checked fuses to no avail...
Mine has never worked since I got this Excursion put together last year. I have read some previous threads that mention two different rear hatch glass defroster grids, one being a higher output grid (and different resistance?) than the other. Is there a chance my system is looking for the higher ohm grid, but my window grid is the lower ohm unit and therefore not activating the timer? I only ask this because my electrical system is M/Y 2002, but my back hatch is from a 2000 M/Y.
Also, I get no indicator light when the switch is depressed. I have tried 3 different switches just because I had extras... no luck.
Any help would be greatly appreciated... tired of frosted windows and mirrors... it's winter in Colorado!
Digging up an old thread - Because I still haven't figured this out!!! Tired of having no defrost in winter!!!
Any new ideas, 2 years later LOL!
I have power to my rear defrost switch (both signal and illumination), I've tried 2 different switches. It never turns on. It's not getting a signal/pulse to/from the GEM to start the timer and run the mirror and rear window defrost... help.
Did you ever solve this? I have the exact same issue.
Tying information from this post:
Fuses: Ok
Relay
Power to PINs 30, 85
NO Power to PINs 86 87
Indicator Switch has been changed out twice. There is power to the switch but no light and no effect.
Any help would be greatly appreciated!
I never solved my issue, but I BET it was the same... having to do with the cluster. I swapped mine years ago and never knew it had to be flashed for options! My cluster probably came out of an F250 that didn't have rear window defrost!!! amazing find, thanks again for sharing!!! Sadly, I sold the EX earlier in the year so not my problem now...
For other's reference, where and how do you get the cluster flashed???
That's the catch, the Hybrid cluster/ecu is an odd duck.
I found a Harley Davidson cluster from an F-250 that I wanted to put in and, like you surmised, that F-250 didn't have the same sort of defrost system. The clusters looks GREAT and now everything works as it should... even that annoying seatbelt nag chime...
